Does spalted wood dry faster?
Thad in middle GA
>I've roughed out a couple of blanks from a log that was on the verge of rot. it's spalted nearly all over, and the blanks seem to be drying faster than usual. is it common for spalted wood to dry faster, or is it that they have already lost substantial moisture from sitting in log form? I don't think itis the latter as they were pretty wet while turning. Does the spalting change the wood cells in a way that lets them lose moisture faster.
Curious
~ Thad
Re: Does spalted wood dry faster?
Brad Vietje
Brad Vietje
>Thad -- In my experience, yes, spalted wood will dry faster. Spalting is basically the early to middle stages of rotting, and the cellular structure does get all messed up, and moisture can escape more quickly.
This can be a problem in pieces with both spalted areas and more sound wood -- if there is a sharp interface, they can split where the two meet unless dried quite slowly.
Safe spinning,
Brad Vietje
Newbury, VT
>The wood you are spalting doesn't dry any faster that other wood it's just that it's been sitting there longer waiting to spalt and losing moisture so when you do cut it up into bowl blanks it has less moisture than a fresh cut bowl blank and therefore dries faster.
