We value your privacy.
>I am going to try to make a swan neck gouge and looked in the archives and didn't come up with anything. My problem is knowing the radius of the arc. I've tried looking on different tool maker web sites to get an idea of size, but can't get any perspective,as to size. Any help will be appreciated. TIA.
>Sorry, I am using regular bowl gouges for my hollow forms and need a swan neck scraper. Got confused writing my post. I'm want to use the swan neck shape with a tool bit attached.
>The radius and the size of the shaft will depend on what you plan on turning. With a 3/8 " shaft expect to go about 3" max. into a hollow form and then chatter problems will start..
>That' what I was looking for. I couldn't find it on his web site so even emailed asking for his help. I remembered seeing it somewhere, just having more senior moments than I like to admit.
>I've made three different sizes of swan necked tool shafts. Just hold your hand up, cup the hand, and use your arm to draw the shaft. Lay it on your bench, and draw one line, following the curve of your and wrist. Then make a couple of different variations of it. Clear as mud?
While this isn't what Don wanted, there is such a thing as a "bent" bowl gouge, which is used on its side for finishing the insides of deep bowls. Robert Chapman, d.b.a. BCWA Tools in England, used to offer this bowl gouge for that purpose, and I own one. I must admit, I have found it easier to use an Ellsworth-style gouge for deeper bowls, but I haven't put much time into this tool. I suspect its more of a problem with straight-across "English" ground bowl gouges, which can lose bevel contact in deep, narrow bowls.
Maybe this will be a valuable collector's item someday (?)
