Finish for cedar
Finish for cedar
Finish for cedar
Steven Smith
>I turned a small hollow form out of cedar. Any suggestions on how to finish it so I will still be able to smell the aroma?
Re: Finish for cedar
Re: Finish for cedar *LINK*
joaz
>Leave the inside unfinished. Maybe a little oil.
make a top for it and everytime it's opened........ voila!
http://www.maine-web.com/woodturning
Carole Valentine
>The smell will eventually leave it anyway. Cedar is a tough call when it comes to finishing. I tried a build of Waterlox to get a high gloss on a piece of cedar. It seemed fine and looked gorgeous. I buffed it put, it on the shelf and two months later picked it up to only to find that the nice smooth oil finish had become sticky. I later read somewhere that the resins in Cedar are similar to kerosene and the vapors will soften most finishes, including oil finishes and lacquer. Maybe Russ, our resident finishing guru, can give us some words on this. I now just leave cedar natural, sand it very finely and buff it.
Re: Carole, I've never had that
Allen Neighbors
>happen to one of my cedar HFs. I have used Lacquer on most of my hollowforms ever since I first turned one. Those of cedar have never had any change in the finish.
I wonder if it has anything to do with not putting finish on the inside... it could be that the oils in cedar wick out the easy way... where there isn't a finish, rather than ooze through the lacquer? Hope Russ responds.
Carole Valentine
>Allen, I suspect it also has something to do with how dry the wood is, but not sure. I can never tell when cedar is dry...looks almost the same to me whether it's fresh cut or aged!
Fog Tanner
>I do some work with Aromatic cedar and have gone to using Shellawax creme or shellac that I mixed up. I have also used Minwax Antique Finish and buffed on the Beall system with decent results.You have to be careful of the recipiant, some people can not tolerate the smell of cedar. So the pieces that I give away are sealed inside and out. I am allergic to it and cannot be around it very long before I get a headache. I use an Airstream and a cyclone dust collector when turning so I don't have the problem unless I get real careless.
I have also used Minwax Antique Finish and buffed on the Beall system with decent results. Most of the cedar I am using has been drying for 20-30 years, and lost most of the smell until you cut into it. The only fresh cut cedar I use is normally for items that get an oil and wax finish.
As a pervious post mentioned, finish the outside and leave the inside unfinsihed and you will get plenty of cedar smell.
No finish
Jorge Castaneda
>In my experience cedar does not like to be finished, I've used extensively when building boats, you paint it and in a few month it is shedding th epaint, in houses, both shingles and clapboards, do not like paint either, but tolerate stain somewhat better, my best luck is to let it weather and it turns a beautiful silver gray.
In blanket chest, we leave it unfinished.
$0.02
Jorge
Addendum
Jorge Castaneda
>I just went to the bathroom and realized I have cedar wainscot finished with polyurethane, that is in perfect health after 15 years.
