Dealing with knots/cracks
Steve Kubien
Steve Kubien
>Afternoon everybody,
I'm working on a cherry bowl and the blank has a knot going through the bottom to the top. It's tight but there are a couple of cracks in the knot and I want to fill them and make them secure. My immediate thought was some thin CA and sawdust, as I have done this in the past. Problem I've had in the past is the marks left by the CA when I am sanding. It has really muddied the look. Anyone else have this problem and if so, how did you deal with it? Maybe the CA isn't fully curing in my non-heated shop and that's the problem? Your help is appreciated....
Steve Kubien
Ajax, Ontario
Re: Dealing with knots/cracks
>Steve Iput a light layer of finish on the wood before applying the CA. That way the CA won't penetrate the wood and stain it. You can sand off the finish and the CA if necessary it will still be in the hole you filled.
Leo Van Der Loo
Steve the knot is drying and the wood of the knot
Leo Van Der Loo
>is getting smaller, so it splits, what I have done, is after rough turning, immediately soak CA into the knot, almost always this will prevent splitting, however if there is a split, like you have in the bottom, I will put a piece of masking tape on the inside over the split, and fill the split from the outside, fill, wait some and keep adding till full, then just let it harden by itself, and yes you will be able to still see the split and also the CA, I don't think there's a way to let it disappear, but if it is a dark knot, and the split wide enough, you could make some fine coffee ground, (real fine) and work it in the crack and then carefully drip some CA onto that.
Here's a picture of a bowl with a lot of splits that are filled with CA and ground coffee.
Have fun and take care
Leo Van Der Loo
Re: Dealing with knots/cracks *LINK*
Ken Grunke from SW WI
>Steve, I refer you to Russ Fairfield's essay on glues, with a detailed section on CA glue (link below).
To fill small and medium sized cracks, I prefer to use whatever I'm finishing the wood with as a medium for "gluing" fine sanding dust into a crack. I usually use a fast-drying polyurethane, but any varnish should work and should be much more flexible than the brittle CA so it won't pop out over time.
Just dab some finish on the spot, and sand in some fine dust with 220, 320, or even 600 if the cracks are small. For larger cracks, do it in stages letting the finish at least get sticky before adding more.
Russ's Corner: Glue and Woodturning
Allen Neighbors
>Most of the time, I do like John does. First a coat of finish, then CA.
Sometimes I put finish on it, and then sand it, while the finish is tacky, so it will fill it with dust. I keep doing the same sequence 'til it is filled.
When you put a blank away... awaiting rough turning... keep a watch on it... at the first sign of dry at the limb pith, coat it with some type of sealer or finish.
This worked pretty well for me when I was making bandsaw boxes from wood that I was curing.
HTH,
Steve Kubien
Steve Kubien
>Thanks for the help and links. I think my problem may have been sanding before the CA dried. In my southern Ontario garage (not heated) it is often around freezing this time of year. I'm thinking that slowed the cured of the CA. Why do I think this? Well, I CA'd a large knot last night and today was able to sand it cleanly. I'll post pictures when I can.
Cheers,
Steve Kubien
