Green fluted, dyed, limed vessel
Bruce Forrest
>This is another in the series of ash vessels which have been turned, fluted, dyed and treated with liming wax. It measures aobut 9 3/4 inches tall. Any and all comments are welcome.
Bruce Forrest
Re: Green fluted, dyed, limed vessel
David Walser
>Bruce,
I like the form. It reminds me of a flower bud. I also like the way the liming accentuates the grain. I also like the fluting. It creates a an interesting rippling effect. As if a pebble were tossed into the wood in the middle of the piece (half way between the top and bottom) with the effect of the pebble rippling outwards, up, down, and around the turning.
dyed, limed vessel-- A couple of questions
Wayne Allen - Carson City. Nevada
>Bruce -- Very nice work. Were the flutes done on the lathe with a router using the indexing wheel? If so, how did you mount the router and did you have a lot of problems with tearout using a router bit? Also what is your liming process and how did you apply it? Thanks for sharing this, it is really a very nice piece. -- Wayne
>Very "organic". I like it.
Re: dyed, limed vessel-- A couple of questions
Bruce Forrest
>Thanks, Wayne. The flutes started out with a router using the lathe indexing. A piece of 3/4 plywood was mounted on the lathe to serve as a table, and a laminate trimmer was mounted on a sled at the appropriate height. Then the router slots were rounded over with a microplane rasp and then sanded. With the ash, there's not all that much problem with tearout. (Worse with poplar, for example) And you can touch up a little with sanding with a Dremel. As for the liming wax, I found that the best applicator was my finger. It's applied sparingly. A little goes a very long way. There are different ways to remove the excess, from just plain rubbing with a soft cloth or panty hose, wiping with mineral spirits, or clear wax, or using 0000 steel wool or sanding. I found that for the most part, I had the best results with steel wool, but experiment, to find out what's best for you. If you get something that you don't like, just remove it all and start over.
Bruce
-- A couple of questions more that I forgot to ask
>I forgot to ask -- What exactly is liming wax and where do you get it?
Re: -- A couple of questions more that I forgot to
Bruce Forrest
>Liming wax is a mixture of beeswax and a white pigment. I called all over town trying to find it, but had no luck. Then I googled it and found a couple of places in Canada that I could order it from. I got mine from Wood Essence in Saskatoon. As far as I know, there are two main brands, Liberon and Briwax. I used the Liberon.
