oneway gouge factory grind
stacey s
>The grind that comes with the oneway double ended bowl gouges How do you sharpen it? It looks to be some sort of traditional grind and I have been wanting to try this grind but don't know how to sharpen it.
Stacey
Re: oneway gouge factory grind
Vincent Welch
>HI Stacy,
It is a standard grind that comes from Oneway. With my double end gouge I created a fingernail grind on one end and brought the wings back slightly but kept the standard grind on the other end. Now if I need to turn away the bottom of a bowl using the standard grind I simply change the tool around in the handle. Two gouges in one. Hope this helps, Vince
stacey s
>How do you sharpen the standard grind? I was just looking at my grinder and it appears that this would best be done using the table attachment with my wolverine system set at the correct angle. Is this correct?
Stacey
Greg Haugen
>Hey Stacey,
I prefer to sharpen my "standard" bowl grinds on the platform. I do use the vari-grind for the "irish grind". As long as its not a short gouge where it won't lay flat on the platform I would set the angle to the nose of the gouge. Then is just a basic rolling of the flute to the sides and a slight handle travel to follow that grind. Mike Mahoney and Stuart Batty, it's on their DVD, recommend grinding the sides first and then just "connecting" the sides with grinding the front-this is more for platform sharpening a swept grind. That way you're less likely to create "wings" or a "crater" on the nose of the gouge. Either way works and you'll get the hang of "your" way.
Hope it helps,
Greg Haugen
Ronnie
>I recently saw the video on the wolverine and they said to grind the traditional grind on a bowl gouge you would do it basically the same as a roughing gouge by just rolling it around
Ronnie
stacey s
>Thanks guys. I thought that is how it should be done but thought that I should ask before I tried it.
Stacey
Keith Tompkins
keith tompkins
>Hi Stacy, Yes, just drop it in the wolverine, with the bevel riding against the wheel, which may take a bit of adjustment. To sharpen, just roll the tool, one side to the other. Once set up, the grind is completely repeatable...one roll, side to side will make it sharp...a good grind to have.
Greg Haugen
>Keith, "drop it in the wolverine"......... Are you talking about the V arm?? I have found that produces more of a "roughing gouge" grind and I tend to like a slight sweep back, not a straight up the side grind.
I assume you would talking about a V arm. Because I don't see why someone would post the same thing that someone else just posted a few hours earlier. That would seem redundant.
Greg
Mike Cunningham (Cape May NJ)
>Stacey,
Use the gouge attachment with whatever system that you use, Wolverine, Tormek Vari-grind, etc, it's repeatable.
Mike
Poll: for Traditional grinds
Greg Haugen
>Just curious on this topic. For those who use a traditional bowl gouge grind (not a irish, ellsworth, or grumbine grind) in their turning.
Do you prefer to sharpen it on a platform? Vari-grind? V-arm? Or another way??
Do you leave the grind full length or relief grind it to shorten the bevel?
What angle do you grind to? 40, 45, 50, 55, etc? Or "I have no idea but it works or doesn't work??
Curiousity is killing the cat.
Greg
Or is it the Vari grind???
Greg Haugen
>Or are you talking about the vari grind??
Greg
Re: Poll: for Traditional grinds
>I have 5 bowl gouges, one has a traditional grind. It's about 60 degrees and I sharpen it on the Tormek because I sharpen everything on that.
Gary in Zirconia, NC
>I sharpen 1 gouge traditional on the platform at about 58 deg.
Bob Fawcett
>I have 6 bowl gouges. I sharpen 1 5/8" traditional for the bottoms of bowls. I also have a 1/4" bowl gouge that I sharpen traditional, but I use it for spindle work like Jimmy Clewes shows in one of his videos.
I sharpen both on a platform. They are around 50 degrees.
bowlman
>Stacey
The older gouges (pre Celtic, Irish, Ellsworth, et. al.) were sharpened by hand or on a jig ... but the basic movement for sharpening/grinding was rolling from side to side along the long axis of the tool.
In use, this "straight across" grind must be used with a heap 'o respect to those sharp corners so close to the front of the gouge.
Also, when used inside, near the bottom transition area and in to the bottom, you have to imagine an "uphill-downhill-across the field" journey. As you move across the transition area, lower the handle and raise the edge (going uphill) then down hill until you are on center line and then ... across the field to Grandma's house we go! Right through the "nub" without so much as a harsh word.
If the transition is very very tight, relieve the heel of the gouge and create a double bevel.
This grind is really underappreciated. Right Wally?
