photo light bulbs
photo light bulbs
photo light bulbs
Bill Youngblood
>I saved the Holly and Bloodwood piece with the bleeding problem. Now I need to know if anybody knows of photo light bulbs that are close to daylight in color. Thanks in advance.
Bill
Re: photo light bulbs
>Bill You can get photoflood bulbs that are daylight balanced from www.porters.com I don't recommend them. They don't last long very long and are moderately expensive. A much better alternative is to use Quartz halogen work lights and buy an 80A filter for your camera or if you use a digital camera simply set the White Balance to the tungsten setting.
The cheap worklights are actually about 2700 degrees Kelvin which is a little low for the tungsten setting but you won't be able to see the difference. I've run tests with my students and they work just as well as 3200 degree lamps for most people.
If you already have some reflectors that take a standard bulb base I can find 3200 degree quartz lights that fit this base. We use them at work.
E-mail me and ask for my handout on John's photo booth. It shows a simply photo booth that you can build and discusses the lighting.
