I agree
Reality Check
>First, the good thing about long grain turning is that, distortion and cracking is less compared to side grain, and the structure of a more closed hollow form as opposed to an open bowl actually contributes to the physical structure of the piece.
What I do, and this works for me! You may find something different that works for you.
In many cases, and depending on the species, if you turn a piece thin enough, you can green turn a piece from start to finish without any extra drying involved. Will you get some distortion?. Yes, is that bad? Depending on the piece it may even add interest to it. Ellsworth turns many pieces like this he just lets the wood �do it�s thing� and his pieces are great. It you are achieving a more of a �perfect symmetrical form� you may need to twice turn it. You will find because of the grain orientation and support characteristics of a somewhat closed form you may only have to Paper bag it dry for 2-3 weeks(paper bags are great by the way, I don�t even need to use shavings in my climate ) , then you open air dry (hanging upside down-do NOT cover opening) for another 3-4 weeks. Most wood are pretty stable at that point unless your blank was too thick. Keep in mind in some species, sapwoods and heart woods dry and or move at surprising different rates which the sapwood is sometimes prone to cracking (Locust for example is bad, heartwood very stable, sap very unstable) in this case I will throw some Anchorseal on the sapwood and bag dry it longer.
All this of course depends on your climate, the wood species and experience with the species at hand . Also, with special pieces or special woods I do dry them longer just as a safety measure.
Good Luck
Reality Check
PS, Lawn paper bags work very well, they are heavier and keeps the moisture in a bit more than thinner bags, but still allows fairly fast initial drying.
