How to add a Collar for Hollow Forms
Jake Niedling
>What is the preferred method for adding the collar to a hollow form? Is it turn a finish collar separately and then glue it on to a finished hollow form or is it to rough shape the collar, then glue it on and finish turn it on the hollow form? I have seen some outstanding collars on HF's, so please share your secrets.
Re: How to add a Collar for Hollow Forms
Re: I learned from Carole, (who
Allen Neighbors
>I think makes the nicest ones), then modified her instructions to what I do now.
After I finish hollowing, I trim the opening to be ready for a collar. Then I take the form out of the chuck and put in the collar wood. I drill the opening in the collar, pre-shape the outside of it, then turn a tenon to fit the opening in the form. Then I part it off and re-chuck the form. I glue the collar in, and then finish turn it.
That's just the way I do it, not necessarily the right way or only way.
HTH,
Dick Hines
Dick Hines
>That is perty much like I do mine, but I use a different chuck for the coller. If you take the HF out of the chuck it may not run true when replaced.
Norm Smith in Nova Scotia
>Jake, After turning the HF I take the piece of wood that I have cut roughly to size, center it against the HF still on the lathe, bring up my tail stock with a live center to hold the piece tightly against the HF. I turn it to fit the opening ( checking the size by backing off the live center ) When I have a fit I reverse it and glue it in place with tight bond and bring up my tail stock to hold it in place until the glue sets up. I than finish the outside of the collar , drill the size hole that I want and finish the rest of the collar.
This works for me.
Norm
Steven Antonucci
Some warning about 2 part forms...
Steve Antonucci
>I've turned a bunch of collars, and I'm typically using ebony to accent some Northeastern hardwood. The two types of wood are night and day in hardness, dryness, and grain structure.
I always try to align the grain in the collar with the grain in the main vessel, knowing that wood moves more along the grain than across it. I've done it wrong once or twice, and the collar eventually separates. Since most of us are turning "green" wood for the main body (segmented turners excluded), you should expect that the wood will shrink along the grain and plan accordingly.
I also tend to sand the pieces individually before joining, since ebony dust has the habit of staining lighter woods. Both top and bottom are complete when I apply glue, and then I just need to apply finish to complete.
Steve
Carole Valentine
>Allen, thanks for the compliment, but I there are tons of folks who make collars far better than mine! Wally, the Master-of-hollow-vessels with-collars, has a paper on how he does it but I can't find it at the moment. Art Liestman also has instructions somewhere. I usually finish the form and finish the collar separately. I rarely turn the collar when it is attached to the form unless I want an absolutely smooth transition. Another thing I do is after the collar is parted off, I will grab the tenon in a small chuck and use a little allen wrench tool to round off the inside edge of the opening so if you put your finger in there, it is hard to feel where the collar ends and the vessel starts. (I didn't have sense enough to do this until Jennifer put her finger inside one of my forms last Spring and said I needed to round off the inside bottom edge of the tenon! Thanks, Jen.) For this to work, your tenon needs to match the thickness of the vessel. I am sure there are easier ways, but I don't like to limit my options by gluing a collar to a vessel before I am sure it is what I want. I have a little box of finials and collars that I have decided for one reason or another were just not right, but they almost all eventually find a home.
Re: Some warning about 2 part forms...
Carole Valentine
>Good point Steve. That's why I use the flexible CA in little dots around the shoulder of the collar. Have not had one give way yet.
Paul Porter
Re: How to add a Collar for Hollow Forms *LINK*
Paul Porter
>I make my collars seperate from the hollow form. I finish both pieces to the point where glueing the two together is the very last thing I do to complete a vessel. I like the shadow line between the vessel and the collar. I aline the grain of both pieces as Steve does. I think it's more pleasing to the eye as well as being more stable.
Here is a piece I did with a double collar. It was an experiment in collar shape with the bottom collar being flat and the top one shaped. The vessel body is mesquite and the collars are desert ironwood (sapwood and heartwood). This is my exchange piece by the way. Some lucky person on the east coast will become the new owner in the next couple of weeks.
Here's a link to my website with more photos of collared vessels.
my website
Carole Valentine
>East Coast? Oh boy - that means I have a shot at it! ;)) Nice work as usual.
The double collar is an interesting idea, Paul. I am trying to decide if texturing, grooving, beading or some other detail on the lower collar would enhance or if it would be too busy.
David Walser
>Paul,
That's a very nice piece. I like the way the two collars compliment both each other and the larger turning.
Paul Porter
Paul Porter
>Hi Carole,
I'm sorry to say it's not you who will receive this piece. I thought about texturing as well, but this piece of ironwood has a nice birdseye figure so I decided to leave it alone.
eliot d
>Steve,Your points are well -taken, but you have it backwards -- wood moves ACROSS the grain not along the grain.
Awww shucks!
Carole Valentine
>But that's OK. I am happy to receive whatever from whomever. :)
Wally Dickerman in Arizona
>If you can access WoW, go to reviews, do a search for collar. I have a tutorial, complete with photos on how I do my collars. Very simple and easy to do.
If I'm doing a piece with a fairly large opening (over 2 1/2 inches) I simply true up an area around the rim of a roughed out and dry vessel and glue on a piece of the wood I want for the collar. It then just becomes part of the blank. I use yellow glue for that. I use med. CA for the attached collars. With a snug fit the glue around the tenon adds to the strength.
Wally
I Should Have Mentioned...
>Don't apply a collar to a vessel unless the wood is dry. It it warps it would probably crack the collar..
Wally
Jake Niedling
>Thanks everyone for participating and the ideas and methods on collars.
