Looking for a light tube ( completely OT)
Dinyar Chavda
>I'm looking for a hollow tube, about 1.25 - 1.5" ID, and about 10' long. It's to go around a chain, will be painted, and will hang from the ceiling, so I need it to be as light as possible. I looked at PVC, but was hoping for something lighter, like, perhaps, cardboard. Can anyone think of any business where they might use something like this for packaging (which I can get as a discard)? I haven't been able to find it on the net so I can buy one in that length.
Re: Looking for a light tube ( completely OT)
C.W.Stivison
>I don't even want to know .
Bill Hale / Woodspinner
>Paper towel tube.
Bill in Casa Grande
Re:I'm almost afraid to ask...
Jamie Donaldson
>... for an explanation??!!The only thing that jumps to mind is a garden hose, but the larges dia. usually available is 1" ID?
Bill Youngblood
>Staples or Office Max
Thin wall aluminum tubing?
Eddie Pacheco, San Jose, Ca.
>This may work better as it for the most part it won't have any curvature to it and will be easier to find.
Leo Van Der Loo
protective fluorecence tube 8' at the borg
Leo Van Der Loo
Dinyar Chavda
>OK. I'll give all your fervid imaginations a rest.
We bought a house, and are having work done on it. In the entryway of the new house is a light fixture that comes down from the cathedral ceiling. While I can get to the light fixture, there is no way to get to the place where the chain is attached to the ceiling without building scaffolding (we want to replace the whole thing, including the chain). So, what we wnat to do is to paint a hollow tube to make it look like wood, slide it over the chain all the way to the ceiling, and have it rest on a Japanese-style fixture that we will take from our old house to the new one. Actually, I will also turn a u-shaped dish and paint that and slide it onto the chain first atop this tube, so as to cover the old fixture cover at the ceiling, which has paint on it. Which is why the tube has to be light, and it has to be at least 10' (that's feet, Bill) long.
Ed Wujciak
>Many sizes of PVC come in both a thick wall and a thin wall version, and the thin wall is pretty light. My HD carries both - I know because I bought the wrong one once.
Bob Moffett
Bob Moffett
>What about using a plastic tube like goes aroung a florescent light? I know they come in 4' lengths and I think they also come in 8' lengths. You could get them at Lowes or Home Depot or an electrical supply store.
Re: wood tube
Brian Simmons, Heflin, AL
>A few ideas.
Use pvc as form, wet veneer, wrap around pvc and tape around it in many places to hold the veneer to the form. When it is dry, the veneer will hold the round shape. You could use super glue to join the edges after the wood tube is dry. You can look on ebay and find some resonable veneer but you will probably have to piece it together (8' lengths are available).
Another method might be to buy some wood veneer edge banding, wet it and spiral wrap it around the pvc form. Let it dry and dab super glue along the length before removing the tube (so that it won't unwind).
Yet another idea might be to spiral wrap paper (adding machine type)around the pvc, tape the ends, apply wood grain contact paper over the spiral paper and then remove the pvc form.
Good luck.
Dinyar Chavda
>Thanks for all the ideas--hadden't even considered the possibility of using the tube as a form!
I'll let you know when we get it done--maybe post a picture.
>When they made the tubing for the Gossamer Condor and Albatross (Unbelievably light airplanes that set "man" powered records) they wrapped light weight tubes with carbon fiber and then dissolved the tube out of them from within. The made wings with something like hundred foot wing spans that weighed under a hundred pounds.
Perhaps you could use the same concept to make wooden tubes. Strip the forms out of the interior.
Robert D. Macgregor
>I used to have something in my golf bag that would have done the job, I think. There were some very thin-walled plastic tubes about a meter long that were used as inserts in the bag (to slide each club shaft into and keep them separated). If sports shops still sell these and you could find a good way to smoothly connect several, they would work well.
BOB
Re: wood tube
Bob Fawcett
>Laminate 2 layers of veneer, and you should have some real strength.
I would think that you could also use lightweight PVC and that your fixture anchor should support it. PVC conduit is liter than shedule 40.
do you need to use a chain?
Robin Corell in Atascadero, CA
>How about using solid wood and ditching the chain? You could rip a 10" 2x2 and run a dado down the length for the cord and glue it back together. then rip it into a hexagon and knock the corners off with a spoke shave. It would undoubtably be strong enough to support the weight of the lamp and it would already be wood so it wouldn't need to be painted to look like it.
Robin Corell
Wilford Bickel
>Dinyar,
Check with some businesses like printers or larger sewing operations that may be getting paper or cloth on cardboard tubes. Based on my mill experience in the textile industry a couple or 3 of the ones used for fabric rolls being shipped to cut and sew plants would be ideal.
Stuart Johnson
>Glue up enough staves to make up the total length but at half the length your lathe will handle. Round off each section than create a tenon on one end and a mortise on the other. Attach two together and bring them inline. Remove one and add the next. Complete this until you have enough to meet your length. If you keep them in order you can then glue them together and an difference in size will not be noticeable.
A lot of work and I'm sure there must be a better way.
don lewonczyk
>How about the foam insulation they put on pipes? It comes in different dia. and im sure can be painted with something without coming apart. Or go to the flat side and ask them guys, you could rip a 2x4 or a 1x4 and bevel the edges, don't know the bevel angles for octagon or what ever but someone over there should know, then glue it up sand and paint. Shouldn't be to heavy and you'll have the real wood look. DonL
