ADVERTISE HERE - FREE TRIAL
About (cellulose) sanding sealer
Leppikallio
>I bet this question sounds somewhat crazy to you but I have my reasons (I guess).
I have used thinned sanding sealer on some pieces which is applied between different grits, one thin coat after sanding and buffed and waxed when dry. However I'm running out of that Chestnut brand sanding sealer. No one is selling (cellulose) sealer here in Finland and getting that can be quite difficult because it can't be shipped via airmail...
The question is can I thin down nitrocellulose lacquer and use it sameway? Can I expect it to dry as fast as that cellulose sanding sealer? Is there some other things I should know?
Re: About (cellulose) sanding sealer
Ken Oakley-Sunny St. Cloud, Fla.
>I have used lacquer as a sealer and find no differance than using sanding sealer. I use Deft brand.
Jorge Castaneda
>As far as I know, the sanding sealer is regular lacquer with cotton fibers added to it as filler, that is what gives the whithish appereance.
>It's my understanding that some sanding sealers have Zinc Stearate in them to aid in sanding. I have quit using sanding sealer and just thin my lacquer for the 1st coats that I apply on the lathe. Then I spray the piece with the same dilution off the lathe. I really can't tell the difference between using the lacquer between sanding grits and using the lacquer sanding sealer so I would say go ahead and give it a try.
Allen Neighbors
>Petteri, I use a mixture of 25%Lacquer/75%Thinner as a wash for my pieces, if I have to CA a crack. It will dry enough to sand in about 5 minutes.
(The lacquer I buy now is "called" nitrocellulose lacquer by the manufacturer, but it is not the same as the nitrocellulose lacquer I used to get. The ingredients label doesn't say "nitrocellulose". It says "acetate"... and it smells like acetate, and not nitrocellulose. But I can't buck city hall.)
I have heard that you can thin Lacquer with Acetone so it will dry even quicker, but I've never tried it.
Ric Taylor
Ric Taylor
>I use acetone for a variety of things, including thinning. But be very careful with it, I have read in several places that acetone can be absorbed through the skin and can cause liver damage that way.
Maybe you have to swim in the acetone to accumulate enough to cause damage, I don't know. But I always wear gloves to be on the safe side.
Ric
Mark Kauder, Phenix City, AL
>Lacquer thinner contain numerous solvents, and the proportions of those solvents give you the different types of Lacquer thinners. Those that dry slower, for hot weather, those that dry quickly for cooler weather, etc.
Acetone is an incrediant in almost all lacquer thinners, and is a larger proportion incrediant in the faster drying thinners.
In cool weather, I just go ahead and use pure acetone to thin.
Mark
Re: I make a lacquer sealer cut...
Jamie Donaldson
>... with a single glub of acetone(that's maybe 1~5%?? per quart), and it is a multi-purpose solution for tearout and sealing.I use my older Deft that has started to thicken, and it penetrates,absorbs a bit of remaining water, and serves as surface prep all in one- an old Minwax Wood Sealer can works great.
Colin Spencer
>I had the same problem on moving to Spain. One of the Spanish turners who visits this forum (Carles) advised me to do exactly what you suggest and I haven't looked back. The nitro lacquer thinned with nitro thinners works as well for me as the Mylands that I used to use in the UK. The upside is it is about 1/3 the cost of the Mylands.
Hope this helps
Colin
