Buying chuck for mini
C.W.Stivison
>Well the first of the month is coming and the retirement check will be here soon and I think I need to buy a chuck for my mini. After reading all of the threads this week on chucks I think the Oneway Talon would be a good choice.I know how much you experienced turner like to help us new guys spend money.
Thanks
CW
Re: Buying chuck for mini
Jim Swank
>I put a Talon on my Delta mini years back, and I've never regretted it.
Leo Van Der Loo
Same here, got 2 now,have fun and take care.
Leo Van Der Loo
Leppikallio
>I'm far from experienced and I also have three Nova Precision midis currently. Currently two of them has different jaws but next time I'm able to make order 1-3/4" spigot jaws will be in it.
Usually I'll need those 2" jaws as well as pin jaws frequently and I don't like to change jaws. Also I don't think that tommy bar operation is problem... I have to have knock out bar for my lathe around anyway and it has same diameter as tommy bars in my chuck. SO I just hold that knock out bar against my belly and use left hand with tommy bar for tightening the chuck. Right hand is free to hold the piece. Here is again one more good reason to have big belly, you can use it like that famous third hand... ;-)))
Without any commercial connections I have to say I like those chucks very much.
Gordon Seto
>The Nova Midi was on sale at Woodcraft for $69 around Christmas. For the price of a Talon, you can afford to buy a second chuck and extra shape jaws. You can use your tailstock as the third hand also. Tommy bar operated chucks are faster action than key chucks.
The long nose jaw set is my favorite jaw. It allows me clear access to the back side of the blank without the interference of the headstock.
If you upgrade to a bigger lathe and larger chuck, all the jaws will fit any Nova chuck. You don't have to re-purchase all the jaws that you already own. That is convenient and money saving.
BTW, Midi is direct threaded; there is no insert. When you upgrade to a bigger lathe that use different spindle size, you will have to use a spindle adaptor. I still keep my mini lathe. The Midis are designated for the mini. Even if I can, I don't think I want the trouble of changing out the inserts each time I use the other lathe.
Gordon
Fog Tanner
>While my "mini" is a 16" 350 lb model, I just bought a Vicmarc VM90 (the lever operated model) for a specific use on a threading jig I am building. My large key operated Vic weighs over 8 lbs and my two Strongholds weigh less than that but more than I would want to put on a threading jig.
I grew up using precision keyed chucks in metal lathes and said I would never have the lever operated ones when I started turing wood. But now I use the VM90 for a lot more than I had planned on, and that is on my 24" lathe. I do like that it spins up quciker and I can stop it ("handbrake") a lot faster than my large Vic or Stronghold. I have used the Oneway scroll chuck a number of times on minilathes and they seemed OK too, not really bad ince you get used to them. The only real problem is not having a spindle lock, which is where the keyed chuck is really nice. Vic also makes a small keyed chuck, but it weighs more for my needs.
