THE WOODRAT IS BACK!
Banjo issues,,,
Banjo issues,,,
Banjo issues,,,
David Hammond, in Powder Springs GA
>I've got an old Wadkin Bursgreen lathe, and I love it. And actually I like the banjo fine, with a clean, lubed bed it slides along rather nicely. And, it locks down firmly. But, it's too short! I can't get close enough to center of the spindle; it's just aggravating that it doesn't have enough length to have a nice range of motion... I smash my knuckles against the edge of the bed trying to move it around.
My problem is though that the lathe is a 12" swing, but can be converted to a 14" swing, with a riser block on the tailstock, and by simply blocking up the headstock, down at the floor. I hear Oneway has the greatest banjo's going, but they have banjos for 12" and 16" swings...
Any brilliant ideas? If the 16" would drop low enough for a 14" swing I'd try that, I just have no idea if it would. And I would have to do the conversion now, which I wasn't planning on doing just yet, but...
Anyway, just looking for some brilliant ideas, as I'm not coming up with any at the moment.
Thanks!
David
Re: Banjo issues,,,
Re: Banjo issues,,,
eaglesc
>Can't you have a tool rest made that is "goose necked"?
Re: Banjo issues,,,
Re: Banjo issues,,,
>That would be my response also is to make some custom tool rests that do what you need.
Re: Banjo issues,,,
Re: Banjo issues,,,
>Thanks guys... I'm sitting here studying my eyeballs out and I'm just wishing I could take the time to work on this lathe, fix the tool rest problem, make that conversion, etc. But, the offset tool rest is a great idea. And acutally, the rest I've got is a custom one, that is a 3/4 round bar right on top of the 1" post, so the old Delta style rests, that slant towards the spindle, should be just what I need - and they have a couple on ebay now...
Thanks!
David
PS I had my measurements wrong - the bolt holes actually would allow me to make it a 16" swing! Back to Humanites CLEP....
Re: Banjo issues,,,
Brad Vietje
Re: Banjo issues,,,
Brad Vietje
>David,
I think you're right on the money anout a rest that leans forward. I need that every now and again on my PM 3520. I also need a smaller rest, but that's another thing...
Careful though -- the Delta rests are a nice shape, but they often have pretty short stems. The PM rests have a longer stem because they are in the habit of leaving the banjo pretty short -- they might work better for you, or maybe a custom, bent-forward design or a small offset block that would be easy for many people (but not me) to make. If you used an offset block, and I'm guessing just 3" - 4" here, it might also bring your banjo up in harmony with your riser blocks.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Banjo issues,,,
Leo Van Der Loo
Re: Banjo issues,,,
Leo Van Der Loo
>David I have made some, (all) of my tool rests, and have a pic' of my last one, they are very simple to make and you can lean them more or less as you like, this type will also bring the fulcrum closer to the work than the thicker round bars, I have made some of those to, (bend ones), if you make the stem as long as you can, than you have a more stable rest also.
If you have any more questions, just ask.
Have fun and take care
Leo Van Der Loo
Re: Banjo issues,,,
Re: Banjo issues,,,
>That looks great Leo! That's exactly what I would like, and I would also love to learn how to make them - but alas, I don't have a welder, or such tools, but I think a Delta replacement tool rest is going to be what I need for the time being...
Thanks guys,
David
Re: Banjo issues,,,
Re: Banjo issues,,,
Gordon Seto
>David,
Brad has a valid point about the Delta tool post very short. I don't know about your lathe. From your description about changing the lathe to different swings, I assume you will need a longer tool post also. I have looked at the Delta toolrest also, and find them too short. I purchased this Oneway toolrest at the symposium. I really like it on smaller turnings. It allows extra clearance on the bottom for me to hook my fingers to. I think the Delta would have limited height adjustment.
I can't convince my wife that buying a welder instead is cheaper in the long run.
Gordon
Re: Banjo issues,,,
Re: Banjo issues
David Hammond, in Fayetteville right now
>Thanks Gordon and Brad, that post does look awfully short on those Delta rests... I'll let you guys know what I decide to do - thanks for all the tips and stuff!
David
Re: Banjo issues,,,
Re: Banjo issues,,,
E.T.
>Gordon, How long (wide) is that Oneway tool rest?
Ed
Re: Banjo issues,,,
Re: Banjo issues,,,
Gordon Seto
>Ed,
It is 6" wide; the 1" post is 4�" long. The price was very reasonable. I got it at the symposium with 10% off and no shipping.
Gordon
