Realigning a swiveling headstock
Dave Belser
>I have a Nova DVR XP, this is a great lathe and I really enjoy it. The one issue that has come up is that when I rotate the headstock out for better access or for large work, it doesn't always line up right when I rotate it back. For those not familiar with this lathe, there are detent positions for the head stock at 0, 22.5, 45 and 90 degrees from the lathe bed, once in the detent you lock the headstock down.
What I have found is that the slop in the 0 detent position allows me to move the spindle center 0.020" So when I swing the headstock back the center can be significantly out of line with my tail stock. As a mater of fact, the first time this happened, I assumed that my tail stock had become out of alignment and so I took the time to realign it as best I could.
At this point I don't have any good fixed reference to return the head stock to 0. To get back to 0 I would need to establish the centerline of the headstock parallel to the ways and then I could readjust the tailstock. From then on I could use the tail stock to indicate 0 when I swivel the headstock back.
So the questions: Do other people have this problem or is my detent mechanism just sloppy? Is there a particular procedure you go through when you swivel your head stock?
Most of the time this is not an issue, as I don't do a lot of critical tail stock supported work, but when I need to it's a PIA.
- Dave
Re: Realigning a swiveling headstock
>Dave I had the Nova 3000 hand had the same problem. The double ended morse taper does solve the problem but I didn't want to spend the money. I aligned the head as accurately as I could and then drilled a 3/16" hole between the bed and the headstock. Then each time I needed to realign the headstock I simply moved it until I could bit the shank of the bit in that hole and locked it down. The bit not only locates the headstock accurately but also keeps it from slipping while you tighten the lock nut. I hope that's clear enough to understand. I don't have the lathe anymore so I can't take a photo for you to see what I did.
Bill Stehman
>Dave, I do 95% of my turning in the 22.5 detent. When I require perfect alignment with the tail stock I slap in a spur drive and live center... nudge the head stock into alignment and tighten the lock down. It never moves out of alignment. I just accept it now and it only takes moments.
Bill
Dave Belser
>Thanks John, I'll look for a place to drill a reference hole. The castings have changed a bit. Did you drill vertically? I suppose I could drill a horizontal hole on seem between the headstock and bed, but I'd be a little nervous about messing it up.
Dave Belser
>So you realign using the tail stock as a reference. Thats what I've been doing since the first time when I mistakenly thought the problem was with my tailstock.
Ron McKinley
>That's the way I do it too. Realigning the tailstock is a real hassel! ......Ron
Carole Valentine
>I think they are all sloppy! It doesn't take much slop to put it off. I do it the way Bill does. I have one of the double ended morse tapers but I find that lining up the spur and live centers does just as well or better. If I understand your problem, you adjusted the tailstock alignment first, now you have no reference to get it back to the way it was? Not sure how to solve that one. I originally tried to realign my tailstock but could not get the bolts free. Glad I couldn't!
Bill Stehman
>Dave, I called the good folks in New Zealand several years ago and they suggested this because everything is aligned during manufacturing... unless you've dropped the tail stock or something...
of course the alignment tool will work more perfectly. They also told me if the head stock moves a bit when tightening the lock to remove it and clean the detent and lock. I've had to do this several times
Thats exactly it....
Dave Belser
>Carol - I need to establish the centerline for the spindle and then make that parallel to the ways. Once that is done I can realign my tail stock. From there on out I can use the tail stock to find center. The only potential problem would be if the tail stock alignment gets altered (as it most certainly will do over the course of time).
This is why Johns method of making a better index hole would be the best route. If I can index the headstock to the ways (once its set up right) then I should never have to do it again. I'm going to seriously consider this.
As far as determining the setup for the headstock, here is my plan -- based on some playing around I did before for another idea.
I have a laser pointer (from a kit) and the size is real close to the hole through the spindle in the headstock. If I wrap a little paper/tape on it fits nicely. I then aim it across the room to a target on the wall about 20' away. I can make very slight changes in the pointer by delicately pushing on the back end that sticks out of the hand wheel side of the headstock. As you spin the spindle the laser will draw a circle on the wall, keep adjusting the laser to make this circle smaller. It is pretty easy to get to where the laser draws a tiny circle on the wall - keep working to minimize the dia of the circle. You can set the lathe speed to 100 rpm and go look at the wall. When done the circle is less than 1/16", I assume that this is mostly from the laser not being dead center in the shaft and a little off of parallel.
The thing is, the 20' base line allows you to get very close to parallel ( 1/32" in 20' ). once this is done I'll lock the spindle and make a target that is referenced to the ways and tweak the headstock until the laser hits the target in the same spot on both ends of the ways.
If this sounds like the hard way or I missed something obvious let me know! The advantages from my perspective is that I have the laser pointer and know that I can set it up as described. I don't need to buy or borrow any precision measuring stuff.
- Dave
Dave Belser
>Bill, it's not that the headstock moves when I tighten the lock, it's that the detent is sloppy. If I have the lock loose and engage the detent at 0, I can still rotate the headstock a "little" a very little but enough to be a problem when the aligenment matters. If it's not alligned when I tighten the lock it stays not aligned. I've talked with Tim Giest - USA tech for Teknatool about other stuf and have nothing but good to say about their support. I might give them a call and see if there is a way to improve the detent mechinisim.
- Dave
Ken Grunke from SW WI
Dave, was there slop in the detent when the lathe was new? Maybe a new detent pin will solve it. Or see about having one made, that's a bit bigger where it counts.
Re: Thats exactly it....
>Dave, the laser idea sounds pretty neat but can't you save some time and trouble by drilling/boring a hole in a piece of wood chucked in the spindle, for the laser to fit snugly into? Voila, the laser is on spindle center, with no fiddling! Then, use the tailstock as a point of reference, comparing the laser's dot with the tailstock in two positions. I'm not sure a laser is the best way, given the fairly large size of it's dot. It may work great if the tailstock ram has a through-hole, and the laser can be projected through that onto a piece of paper secured at the outer end. I dunno... still it sounds like more trouble than necessary. The double-ended morse taper is a great way to go, but you need to make sure the headstock spindle is lined up with the bed first, that's the most important thing. Then align the tailstock to that, or it may have to be the tailstock first.
Laser pointer
Dave Belser
>Ken, unfortunately the laser pointer is really just a laser toy not a precision tool. The laser itself is just a little chip inside the thing, and they don't make much of an effort to line it up with the body. I've done the laser trick a few times when I needed a center ref for other reasons. It takes less than 10 minutes to do if you have got the process figured out.
As far as the dot size, yeah it's kind of big but as long as you work with the center of it, it works out OK.
- Dave
>Dave that's what I did was drill right on the seam or joint parallel to the top of the bed. I couldn't tell that it did any damage that would affect how the lathe works. You only have to drill in 3/8" or so.
Re: Laser pointer
>I agree with Dave. I thought about buying a boresight lazer scope alignment tool but then you would still have to turn a perfect morse taper and a hole for the boresight tool. If your off any at all it won't be accurate. I'm sure a good machinist could do it but probably not me.
Another Way
Ed in Leaside (Toronto, Ontario)
>The laser will probably not be accurate enough. To check headstock parallel to the travel of the tailstock, this is your first priority, turn 2 spindles with a Morse taper to fit your headstock. One should have a very short stub protruding, the other should reach the live center's point when the tailstock is nearer the end of the bed. Stick a piece of card (or something markable, removable & replaceable as you'll presumably be checking this few times) and scribe a circle on the end of each spindle with the live center point. I'm assuming you'll get a circle. ;-)
When the following conditions are met: both circles are the same size, the live center tip is on a line drawn horizontally through the scribed circles' centers, and the tip is on the same side (near or far side) of the circle: the headstock spindle is parallel to the bed in both x & y axis and the live center point is on the x axis of the headstock.
Now you can adjust the tailstock to the headstock with the quill in both retracted and extended positions.
It could be worse. I have a GI 25-650 16x43 with sliding & swivelling head ... and a 62" extension bed.
