Chuck or Face Plate
Chuck or Face Plate
Chuck or Face Plate
Bob Herrman
>I Have several large Cherry blanks 14 to 18 inches. I have a talon chuck with #2 jaws and a 4 inch oneway face plate. Assuming that I obtain #3 jaws, would this be safe enough to turn or should I break down and purchase a bigger chuck?
Re: Chuck or Face Plate
Allen Neighbors
>I've cored out a few 22" dia chunks of Oak, Honey Locust, and Sweet Gum, all of them wet, with a little SuperNova2 chuck with 100mm jaws... so I think your Talon should be fine. (I also used a 4" faceplate, until I got the tenons made.)
I would start with the faceplace...
Jeff from MA
>That would be a very heavy blank to rough out with the #2 jaws, even if it was perfectly balanced. A good catch could easily lever the blank right out of the chuck. A blank this size will require some time to turn and I would also be weary that just normal turning stresses would loosen the jaw grip while you are working.
I am guessing that blank is at least 4-6 inches thick? If so why not start with the faceplate (with or without a waste block) until most of the material is removed.
If the design you are working on requires you to reverse turn the piece one or more times you always have the option to switch to the chuck after the blank is in balance and its mass and size have been reduced.
Re: Rough out between centers,......
Jamie Donaldson
>... then no chuck or faceplate is needed until piece is more in balance. Then chuck with #3 jaws should do the job just fine. Forget the faceplate!
Wally Dickerman in Arizona
>The most secure way to handle the large blanks would be to install the faceplate on what will be the top of the bowl, then bring up the tailstock for support. You can cut a tenon for the #3 jaws and rough out the outside of the bowl this way before reversing the bowl to install it on the chuck for hollowing.
Wally
>Both Wally and Jamie have given you excellent safe choices. Personally I start everything between centers but on the rare occasion where I don't I always use the tailstock as long as possible. Wood is somewhat unpredictable and things happen. I usually turn the outside of the bowl first then reverse and turn the inside. I will often use the tailstock even then when I first rough out the inside. I can take bigger cuts and I know it's not going to come out.
Leo Van Der Loo
Re: Chuck or Face Plate *LINK*
Leo Van Der Loo
>Hi Bob, I almost always start with a face plate if the blank is larger than 12-14", I have done some like that and larger just on a wood worm screw, but a face plate is safer, after you have shaped the outside there is a lot less weight and the blank is also balanced or close to that.
Than you can put it on your face plate and do the hollowing.
I happen to have a photo album with the steps I take when turning down a rough blank and then hollow it.
Have a look if you like, but whatever way you decide to do it, if it works for you, than thats the way to go.
Have fun and take care
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum26.html
bowlman
>Bob, to help you with your dilemna (and I always want to help), just ship those nasty old cherry chunks to me. I'll see that they are properly disposed of!
Dick Gerard
aka bowlman
Re: Chuck or Face Plate -- kinda long
Brodie Brickey
>From Oneway's website "If your lathe is more than a 16" swing, we recommend our Stronghold Chuck" URL: http://www.oneway.ca/chucks/talon.htm
The Stronghold is intended for blocks larger than 16". If you are going to be doing a lot of turning in that upper range, I'd recommend getting the larger chuck and specifying at time of purchase either the #3 or #4 jaws (since it normally comes with #2 which you already have). I thought the jaws were interchangeable between chucks but it doesn't look like they are going by part numbers on Oneway's site, which is unfortunate.
Yes, you can turn between centers and if you use a forstner bit to "deep seat" the spur drive you can probably turn just fine.
The problem, I believe, comes into play once you've turned your tenon. Once mounted on the chuck, you're now asking the #2 jaws to trust to hold a very big block of wood. Moving up to #3 would help a lot, but would it be enough if you tried to core out a half dried maple bowl blank? It wasn't for me and I have a stronghold, the blank was only 13" in diameter, I sheared the foot off twice with #2 jaws. I went out and bought a #4 jaw set and have been very happy since. I will purchase the #3 set in the near future for other stuff in the middle range, but for now moving up to a very large foot gives me greater options.
If a stronghold isn't in your price range now, faceplate and bring up the tailstock as much as possible until you're down to thinner walls. The faceplate is kinda old school since chucks are so much faster, but they are generally very safe with the right screws. It may take a little more time with a faceplate, but reconstructive surgery takes a lot longer, just ask your Dentist.
May all your turnings be smooth,
Brodie
http://www.SmoothTurning.com
Man Rule #2
Bob Herrman
>Thanks to you all for your responses. In keeping with the sprit of Safety "first" and Man Rule #2 of "obtain more tools and stuff" I will look into the Stronghold Chuck.
Thanks again.
