Re: Do you know how to cut this log?
Al Crandall (N.E. of Indy)
>Do you know how to cut this log? You mention that you are a relative newbie, so I wonder if you have noticed the off center pith, and I wonder if you know how to deal with it? Too many people look at a log end and if they see a small crack at the pith they will use it to align the splitting cut. Then they take it home and slap it on a faceplate and turn a bowl. This results in a bowl with the hourglass or oval pattern inside the bowl not being in the center of the bottom. The grain pattern is shifted to one side and the growth rings are tighter on one side of the bowl than the other. The bowl was �done in� by the first chainsaw cut and never stood a chance to recover. The subsequent viewer of the bowl is presented with a symmetrical shape and an asymmetrical grain pattern, which clash with each other.
So how would I cut this log? First item of business is to find a line that goes through the pith, and has the pith on its exact center. In your photo, it looks like this line might be twenty degrees counter clockwise of vertical. A cut on this plane will result in a bowl blank to the right which is nicely proportioned and has even grain patterns, and another bowl blank to the left which is probably too deep for its diameter for most applications. I would make another cut parallel to the original that would result in two more blanks which might make a nicely proportioned and even grained bowl from the piece nearest the bark, and maybe a shallower bowl or platter blank from the piece nearest the pith. And all three blanks would have the optimum grain pattern for turnings.
So what about that crack I mentioned before? Leave it behind with the chainsaw shavings. If it is of some consequence, make two splitting cuts parallel to, and on each side of, the proposed first cut line. This might reduce the size of the largest bowl you could make, but the quality and overall appearance will improve enough to make it worthwhile. I have never had anyone pick up a bowl and say, �Wow! What size blank did you start out with?�
On really large diameter logs, I sometimes make the two splitting cuts a little wider than necessary to remove an oblique crack. This thick slab which has the pith in the middle of it can then be split through the pith resulting in two more blanks which are true �quarter sawn lumber� orientation, and will make bowls with the grain showing in parallel lines straight across the bowl from rim to rim. It�s an orientation not seen a lot in bowls, but can be interesting sometimes.
