WE MOVED...
OT: Chainsaw
OT: Chainsaw
OT: Chainsaw
Don Henthorn
>Got out my Husky 345 today to cut up a small tree in the backyard that is growing directly beneath a larger tree. It is going no where so I need to remove it. Pretty small but I can get a few turnings from it. However, when I tried to remove the chain cover so I could install the chain the cover wouldn't come off. I had the brake lever all the way back but the brake wouldn't release. I finally got the cover pried off without damaging anything. The drum had some corrosion on it, but not bad. I smoothed it down and tried to put the cover back on, but it won't go. The brake band appears to be stuck at its smallest diameter and won't go on over the drum. I tried turning the little cog wheel at the end of the brake band, but it won't move. Has anyone else had this experience or have any ideas?
Re: OT: Chainsaw
Re: OT: Chainsaw
Jorge Castaneda
>Hi Don,
Yes I had that problem at the beggining of this winter, I just could not take the cover off, so I went to the dealer, he reassemble it and after several tries he made the brake disengage, then everything was back to normal.
I think part of my trouble is that I am not that strong anymore.
Jorge
Re: OT: Chainsaw
Re: OT: Chainsaw
Don Henthorn
>Thanks for your reply, Jorge. I know I should be able to move the little cog like thing at the top to line it up with the recesses in the brake lever, which would release the band, but I am afraid of breaking something because the only thing to pry against is the thin web between the recesses. Guess I'll have to risk it.
Re: OT: Chainsaw
Re: OT: Chainsaw
Jorge Castaneda
>Don,
If I was in your predicament, I'll take the saw to the dealer, if that is not convenient, reassemble it and then disenge the brake, no risk taking, if you brake something is going to cost you more in downtimw and money; maybe a generous dousing with penetrating oil before reassembly may help.
Good luck
Jorge
Re: OT: Chainsaw
Follow up.
Don Henthorn
>This should show my stupidity. Finally figured out that if I put the lever in the brake position, fitted the cover up as tight as I could at the forward end to get the little cogs aligned with the spaces in the brake handle that I could get enough purchase on the cogs to unlock the break. Worked like a charm. The cover would slip on just like it should, BUT I HAD too see what was going on. I took the cover off the brake band spring and link mechanism and it was easy to see how the thing worked. My wife pointed out that the spring looked like it was bulging a little under the tension and I agreed and set the cover back in place and started to insert a screw and BLAM!!!! The whole mess flew apart. That spring was strong for these old hands. I thought I was going to have to take it to a shop after all, but finally, with the help of my wife, bless her soul, I managed to find a way to get it back together. Now I have to mix up some gas and see of it will run.
