ADVERTISE HERE - FREE TRIAL
Ok, what did I do wrong? Bit long
Steve Kubien
Steve Kubien
>I was working on an elm plate last night and messed it up REALLY good. Here's the situation....
Attached a faceplate, trued it up and shaped the bottom to include a stump for my 4-jaw chuck. Sanded it, finished it...great. Reversed it and started hollowing. Some funky tearout and some chatter marks were cleaned up between light passes with the bowl gouge, scraper and 80-grit gouge. Now the bad-ness....
I adjusted how the jaws gripped the stump to effectively 'raise' the plate in the jaws. Some fiddling got it running true and I proceeded to use the long point of my skew (pointing down) to try to part it off. MAJOR catch and skid which took the skew 1/8" in to the bottom. I managed to save it by thinning things further than I wanted and went for my parting tool to finish up. Same thing happened. Decided to scrap the piece and cut it in half to see how I did at getting even thickness throughout. (Pretty happy with what I saw.)
Both the skew and the parting tool were freshly sharpened. Are these tools not to approach the flat grain in faceplate work? Am I using them wrong? Could it have something to do with the ladder I drove under while running over a black cat during the full moon on Friday the 13th?
Thanks for your help on this. Too bad it was to be my exchange present. Hopefully things will work out better next time (later tonight).
Cheers,
Steve Kubien
Ajax, Ontario
Re: Ok, what did I do wrong? Bit long
Colin Spencer
>Steve
IMHO the skew is definitely the wrong tool to use for this and depending on the size of the chuck tenon the use of the parting tool is far from ideal too. Check your chuck jaws you may find a nick from your skew or parting tool that caused your problem.
The best way without a vacuum chuck or 'cole' jaws is to reverse the plate again onto a padded disk on a faceplate and bring the tailstock with a revolving centre up for support and use a small bowl gouge / spindle gouge to turn away most of the tenon just leaving a small piece of wood for support for the tailstock revolving centre. Remove from the lathe and carve the small piece of wood away and sand to finish.
I hope that this helps
Colin
Ed Kelle
>When you moved it up in the jaws it no longer was resting against a horizontal surface on the top of the jaws and was less stable. I wouldn't use a skew in that type of cut on facegrain work as well. If you can reverse chuck it to turn away the spigot on the bottom that is best, otherwise leave extra room above the chuck for parting away with the parting tool and do it slowly and carfeully, give clearance cuts. good luck and have fun
Jorge Castaneda
>Steve,
Collin an Ed gave you good advice, I want to add this, my parting tool nowdays is a dozuki saw, I make a starter with a detail gauge, (it can be a s bad as the skew for catches) or start the part with a 1/16' parting tool and then switch to the dozuki saw, then reverse chucking and clean up.
$0.02
Jorge
Wrong tool...
Peter Teubel
>There are very few hard & fast rules in woodturing, but you hit one of them (IMO).
A skew chisel is *ONLY* for spindle work (i.e. grain running parallel to the bed ways). It is uncontrolable in face grain orientation (grain running perpendicular to the bed ways).
Bob Fawcett
>Jorge,
You're just sawing it off, not running the lathe right?
Re: Bob, sometimes when I have a
Allen Neighbors
>small tenon left on a piece that I'm finishing the bottom on, I will use an 18tpi hacksaw blade to part that small tenon off with. I have a rubber handle on it, use the blade in pull direction, and stand on the backside of the lathe, with the lathe running slowly, and stop the motion just before parting. Make sense? :o)
Allen Neighbors
>Steve, if you were using the skew point down, you were basically using a wedge. I'd say use the parting tool, but with the shoulders not against the bottom of the piece, your cuts would have to be so light, that it would be interminably slow. That's just not a good grip on the tenon.
You Got it!
Jorge Castaneda
>Hi Bob,
yes I cut with my right hand while the left turns the piece, the saw has 26 theet, so they are very small and sharp. Give it a try and tell us how you like it...
Jorge
Leo Van Der Loo
Leo Van Der Loo
>Hi Steve
Steve if you have a face plate, screw a piece board or plywood that's bigger than your plate, turn a recess in it that your plate just fits in, put the tailstock center against the tenon, than just turn all of that away but the very smallest center part, than take the plate out and hand cut or power sand the little left over stub away, and your all done.
Have fun and take care
Leo Van Der Loo
Leo Van Der Loo
That's suposed to be screw it to a face plate OK
Leo Van Der Loo
Steven Kubien
>So basically, a jamb chuck of sorts?
Steve Kubien
Leo Van Der Loo
Yub
Leo Van Der Loo
