We value your privacy.
>I only seem take pictures of my turings when they collect. Finally got around to taking some. After yesterday's discussions thought I should finally post some of my stuff.
>Bill, You should post your work more often, nice piece with a very good finish. Since you ask for critiques, you might want to "lose the sheet" as Jamie would say and use light poster board to better draw attention to the work. Jamie must be out somewhere confiscating cameras and blue table clothes or he would have commented. ;)
>HI Bill, Here is my critique for what it's worth. Your piece is quite nice to look at, but a couple of changes would make an improvement. First, the curve from the rim to the foot is not a smooth continuous curve...it's got an abrupt change just below center. That causes the viewer's eye to focus there. Second, the chuck (I'm assuming you are using a chuck) has dictated the size or the foot, making the chuck a design consideration. A smaller foot would do two things..first, it would allow more room to continue the curve, which would help create a flow from top the bottom, and it also creates a sense of lift. The bigger foot acts to anchor the form to the surface which it rests on....giving a heavy appearance.
I understand what you are saying concerning the foot, but how do you make that design "modification" if the wood is only so thick? You still need to grab hold. I have noticed the chuck does determine many of my foot sizes and I am trying to work that out.
>... needed here! I suggest you find a photo spot with a wall behind-I hang a white vinyl window shade (on a pull down roller)for a wrinkle free backdrop, easily rolled up for out of the way storage and cheap! It would help show some of the bowl interior as well as the profile if you raised the camera to a slightly higher angle.
>.....bowl on a jam chuck, held in the chuck jaws and tailstock against the base. Then you have easy access to the base and can make it any size you wish.
>Hey Bill, some of this will come with experience....if you turn the inside with a flat bottom, you're stuck with it. With some practice, you'll turn the outside as far as you can, and then measure the inside depth. Reverse the bowl to gain access to the base, then finish turn the bottom, checking the thickness as you go. No more chuck problem!
>Just ask for "foam core". You can also get it at photo shops. It's lightweight, and you can get it with foil on one side... I think... not to sure about that.
