Casters? Mobile Bases?
Jim
>I'd like to swing my 3520 away from the wall once in awhile without pulling a groin muscle! Any innovative ideas out there for lathe mobility? Make? Buy?
Re: Casters? Mobile Bases?
>Jim I'm looking for the photos of my removeable stand. I need to move the lathe today so if I don't find them I'll just shoot some more. I made wooden supports with big pneumatic wheels. I jack the lathe up with a rolling floor hydraulic jack that I bought at Auto Zone for $16. I got the wheels from surplus. I was able to load the Powermatic onto a trailer by myself when I moved.
I had borrowed a truck and trailer. I rolled the lathe up the ramp (my help was late). I was so proud of my mobile base idea. Then I cleared the top of the ramp and the lathe took off down hill toward the truck dragging me kicking and screaming all the way. Lathe-750lbs, me 162lbs DUH! Fortunately I had just enough friction to stop it from hitting his truck. To bad there's never a video camera around when you need it.
Gary Ljostad
>Here is what I use for my 3520. It is made from angle iron, threaded rod, large nuts, and vending machine casters. A welder friend put it all together for me. Hope this helps.
Carole Valentine
>John, you just made me spew coffee all over my keyboard! What a mental picture your post produced!
Brent at Robust
>Looks like you also have a Vicmarc outboard turning attachment bolted to your PM. How do you like it? Thanks, Brent
homemade powermatic mobile base
>I hope these photos work. I put long lag screws through the metal and into the 2x8's. There is a slight gap between the metal and the wooden L. This fits under the lathe legs. I cut a gap in the middle for my hydraulic lift. The wheels on one end swivel and the ones on the other end are fixed.
Re: homemade powermatic mobile base
Dennis Yoder
>When I need to move my 3520 a little way I just chuck-up a chunk of wood way off balance. I turn up the speed until the lathe just starts to jump and then gently push it where it needs to go. ;) Dennis Y
