Kelton Hollowing tools
jack dolan
>Need suggestions on keeping a good edge on kelton hollowing tools.
Re: Kelton Hollowing tools
stacey s
>I am not familar with these but I just looked at picture of them and would think that unless you really mess up the edge by hitting rocks then you would probably want to only hone them with a diamond hone to keep them sharp. Hopefully someone who has them will chime in to say exactly how they keep theirs sharp.
Stacey
Barbara Gill, Remlik VA
>I use either my India stone or diamond hone, whichever I can find first. I just make several upward strokes along the edge (side). I never use the stone on the top of the cutter. You will probably get some better directions from others who also use the Keltons.
Carole Valentine
>I use the same method Barb does except I use a hard Arkansas stone which seems to work better than a diamond hone. I run it up/diagonally, keeping the bevel flat against the stone. There is a thin layer of some sort of metal on the top surface (can't remember what it is) that you don't want to remove so don't go there. I have only once put them lightly to a 120 stone on the grinder. Honing is generally all you need.
Dawn Adams
>I just gently touch the bottom edge up on my grinding wheel along the original angle. I have never sharpened the top.
Bruce Wiseman
>From the Kelton web site:
Tool Sharpening.
Carefully observe the original shape of the cutting tip. Sharpening should seek to maintain these proportions and angles. The tool cuts by way of a raised burr on the tips edge. A few upward swipes with a diamond honing stick or common slip stone will maintain a fine edge. Avoid grinding until resharpening becomes necessary.
Remember to keep the rounded off area on the cutting tip maintained as such after regrinding as this serves to minimise 'dig-ins'.
jack dolan
>Thanks for all for all the post's. I will continue on. Jack D.
Barry Turner
>The best info on how to use and maintain Kelton Hollowing Tools can be found on Kelton's website. You really should read it.
http://www.kelton.co.nz/holuse.html
Greg Jensen
>Do not use a Diamond hone, they are not course enough. A course diamond is 220 grit. Use a slip stone or hard arkansas. I prefer a medium slip stone. These more course stones raise a bur better on the hard face of these tools.
Greg Jensen
Allen Neighbors
>I have yet to identify the "rounded off area" on the cutting tip. :o(
And I shake to badly to 'hone' with a stone of any type; I've just touched one of them to a stone once, to freshen up the edge.
Re: Duh!!! Disregard my post!
Allen Neighbors
>I don't have any Kelton "Hollowers". My Keltons are for coring. :o)
