Eucalyptus vessel
Eucalyptus vessel
Eucalyptus vessel
stacey s
>Well all the talk about lurking and post has gotten the lead out of me so hopefully I will start doing a better job of participating instead of just lurking mostly. He is a picture of a eucalyptus vessel I did recently. It is 5" in diamter and 3" tall with an ebony collar. Finished with semigloss lacquer. Comments and critiques welcomed.
Stacey
Re: Eucalyptus vessel
Jim Shaver Oakville, Ont.
>Hi Stacey,
I really like it, the dark rim compliments the richness of the eucalyptus.
I have never had luck with the proportions in this shape, I think you did well.
Take care,
Jim
Ray Johnson
>I just got some eucalyptus last week. Would be nice if it was any where close to the color of your vessel. Very nice job.
stacey s
>Thanks for ya'll comments. I really enjoyed working with this wood. Unfortnately When I got the tree It had been dead awhile but was still standing It had bad checks in it and I got very very few usable blanks.
Stacey
Carole Valentine
>Glad you decided to post some pics Stacey! Both pieces you have posted are of a form that I like but find very difficult to do. I can never hollow into that shoulder area properly. What tools do you use for that?
Since you asked for comments, the only thing I might change on this piece - and I am being picky here - is what appears to be a slight hump on the lower part of the collar between the edge and the upward transition. The more I look at it it though, the more it seems that it may be due to the camera angle.
stacey s
>Thanks Carole, Yes these are very difficult to hollow. I haven't been able to get them all hollowed exactly how I wanted to. This one is actually in the neighborhood of 1/2" thick. But you could never tell it by holding it. It is feather light. Part of this being that it is very very rotten. It took lots of sanding with 80 grit to get an acceptable surface on it. With the walnut one it is much thicker 1/4-3/16 thick at most I don't remember right now. Thank you for the critque as well you can never get better unless someone tells you what you are doing wrong. The hump you are talking about I believe is from the camera angle. I still have this one in the house right now and went and looked at it and it is a continoius curve from the top of the collar to its base again thanks.
Stacey
