Earring hoops
Earring hoops
Earring hoops
robo hippy
>I have some one who wants some wood earing hoops. About 3/8 inch diameter, and about 1 1/2 inch round (the kind that go through the ear). I can figure out how to turn the outside, and part of the inside (turn cylinder, round over top and bottom of the outside before parting off which covers about 3/4 of it), but how do I finish turn all of the inside (the other 1/4)? Compression chuck? End grain wood cylinder with saw kerfs and hose pipe clamp? Do I turn flat grain, or end grain? Would it be best to laminate up some of my own plywood and then turn? Any suggestions will be welcomed.
robo hippy
Re: Earring hoops
Re: Earring hoops
Ken Grunke from SW WI
>How about thin veneer rolled up and glued with epoxy or CA glue. Seems like that would be the strongest. Solid wood, end or side grain, would be easily split.
For turning a small ring like that, I thought abou an expansion chuck from a dowel with a couple radial cuts through the end, 90 degrees apart, and a small wood screw in the center to expand the "jaws". Or, just a plain old friction mandrel, with a very slight taper along it's length to jam the ring onto.
But neither one of these methods allow turning of the ID. You could have a cup chuck, to hold the ring's OD for that--shape the OD on one of the first two methods, then the ID while it's in the cup chuck.
Are these actually going through the ear's skin?
Re: Earring hoops
Re: Earring hoops
robo hippy
>Yes, larger diameter rings. A style of ear ornament, plugs, and rings of wood. I have seen some over 1 inch in diameter. It was radical for me to get one earring in the 70's. Rather tame now.
robo hippy
Re: Earring hoops
Re: Earring hoops
>If you have scroll chuck with a set of jaws the correct size you could chuck them.
You could use a piece of PVC with slots in the ends and a hose clamp. Be careful. That hose clamp can be like a weed eater if the strap is long and a real knuckle buster even if its not.
If you can turn the ring and nearly complete the inside, you probably don�t need to hold it too tightly. In stead of a hose clamp, you might be able to use rubber bands or bungee cord wrapped around the outside.
Another idea is to take a set of jaws and perhaps glue a piece of wood to each and either turn a recess in them to hold the rings or screw in some �posts� with rubber grippers and make a tiny set of Cole jaws. Some of my jaws have threaded holes in them for �accessories�. Now I know what I could use them for. Been wondering.
Or go the �other� way. Turn the inside first and then jamb it on a mandrel and finish the outside.
I tried a bracelet or two. Did not laminate them. They broke easily and flew around the shop. Wear your face shield. Consider laminating the rings.
Don�t you have to cut these apart to allow them to be inserted in the ear? Seems like a chance for some off center turning to make them tapered around the rim.
I hear tiny little boxes are the rage or ear inserts. Can�t imagine what they would stash in them.
Re: Earring hoops
Re: Earring hoops
Sonja Lemon
>How about turning them as loose rings? Then split to remove from the cylinder and reglue if desired.
