Turning Brass on a wood lathe
Steven Antonucci
Steve Antonucci
>I bought some brass bar stock for a special project I am working on and I plan on turning it on my Nova. I figure on covering the ways to catch the filings and curlies, and turning at a very slow speed.
What can't you do with brass that you would with wood? can it be parted? Can it be cut with a spindle gouge? Or will I be scraping it forever?
Any lessons learned appreciated before I hurt someone (like me)...
Steve
Re: Turning Brass on a wood lathe
Re: Turning Brass on a wood lathe *LINK*
Mike Cunningham (Cape May NJ)
>Hi Steve,
I know that we've emailed in the past but I confess that I don't recall your proximity to my AAW Chapter. At any rate, our meeting next month (Feb 20, 2007) will be held at the shop of a friend and local coppersmith Steve Bradway in Rio Grande NJ about 10 miles north of Cape May. Steve will turn some items from copper stock and his demo would prove interesting and informative to you. As well, I'm sure he could answer whatever questions you have regarding metal spinning. See the link for our chapter Website and additional info.
Mike
President
Cape Atlantic Woodturners
Robert Henderson
>I have used brass plumbing fittings for ferrules for tool handles. I used a skew chisel and a gouge. No problems.
Beware of the chips. They can be like super fine wires and stick into anything they touch (especially flesh).
It's like working with fiberglass. Eye protection is even more of a must than usual!
Steven Antonucci
I am as far away from Cape May as a NJian can be
Steve Antonucci
>If you drew a diagonal line from the lower right where you are to the upper left where I am, you'd probably find me. South of you, I'd be swimming. North of me, I'd be in NY.
Thanks for the info though. I'll probably wear gloves and take it slow.
Steve
Steven Antonucci
Appreciated.
Steve Antonucci
>Don't need an emergency room visit. My medical coverage isn't that great!
Steve
Re: I am as far away from Cape May as a NJian can
>Yes, he wears gloves while turning metal. If you'd like to attend this particular meeting I'd be happy to put you up for the night. Bill Grumbine has stayed here several times and left none the worse for wear, however he does have a new nickname which unfortunately can't be posted here......it has to do with fishing and his ability with the bait.
Mike
Re: Steve, I've turned brass pipe
Allen Neighbors
>fittings into ferrules for wooden screwdriver handles on Old Griz. I used my Oland tools with 1/8th and 3/16th inch HSS cutters. I turned it on slow speed, which is about 250 rpm (as close as I can find out)and it turned really smoothly. No problems.
Awaiting the arrival of our
third winter ice storm in
Childress, TX
Allen
eaglesc
>I've turned brass withthe regular $10.00 HF chisels, softer thqan some woods I have turned easier than plexiglass.
I have even turned steel using the $5.00 set of Carbide tips from HF and held them in a pair of vise grips.
>Steve I've turned a lot of brass. It turns just like wood except you have to take very small cuts. The feed rate of the tools is quite slow. As long as your getting curls your doing it right. It will dull the tools quickly so sharpen often. You can scrape and shear scrape. I always start with a spindle gouge and usually get what I want. Parting is the only thing thats different. It cuts really slow and tendds to chatter. I use about the same speeds as wood.
If for some reason the brass is hardened and won't cut heat it red hot and quench it in water. This will soften it. Yes I know it's the exact opposite of steel.
The sanding dust can be dangerous so use good dust collection. I sand to 600 grit, then 4/0 steel wool and then polish with white polishing compound.
Finish polish w/ "Brasso"- 'NM'
David Staeheli
