inserting a spur drive
eliot d
>Do you hammer it in or do you use the tail stock quill to push it in?
eliot d
Re: inserting a spur drive
Russ Babbitt
>No hammer, just push it in by hand.
Jorge Castaneda
>Elliot,
The way I learnt it is to cut grooveswith the band saw ( a cross) and then tap it in with a wooden mallet, not a hammer, you may be able to mount a piece of white pine just pushing with the tailstock, but with any harwood you will be out of luck.
That said, if you do not have a band saw, you can use a hand saw to make the shallow grooves, also, Lee-Valley sells a gizmo you hang in your wall and then present the blank to it and whack it, presto, your grooves are done.
Have fun
Jorge
Allen Neighbors
>Eliot, I just push it in with my hand... sort of "pop" it in... not too hard, and not too easily. Tailstock pressure on your piece should seat it further, if necessary. You'll still have to use the knock-out bar to remove it.
Just a hint... I blow out the hole and the taper, before I re-seat a taper. DAMHIKT. :o)
adrien
>When it's half a log for a large bowl, I use a (now ruined for anything else) wooden mallet. Hand pressure's not enough and I don't want to damage the headstock bearings.
Seat it with a wooden mallet
Terence Rice
Re: Sorry, Eliot, I thought
Allen Neighbors
>you were referring to insertion of the spur drive into the headstock... not a piece of wood. For insertion into wood, I drill a 1" hole, 1/4" deep, mark it with the spur center, hit the marks with 1/4" chisel, then a mallet to seat the spur center.
Re: Seat it with a wooden mallet
eliot d
>Thanks for the responses. I was referring to inserting the spur center into the wood (not into the spindle.) I have been squeezing the log between the spur center and the tail stock and tightening the tail stock quill - including hard woods. I see that some do it that way. Most, it seems, use a wooden mallet to hammer it into the wood first. Adrien raised the issue I was worried about, namely that using the lathe to do the work could damage the bearings. I haven't noticed any bearing damage so far, but to be on the safe side, I think I'll take most of your advice and hammer it in first. Thanks again.
>I simply insert the drive spur by hand. Then I use the tailstock to seat the spur into the wood. The tailstock doesn't have bearings so you can't damage that. You could feasibly damage the screw on a reallyl poorly machined tailstock. I also sharpen the teeth on my drive centers so they bite more positively.
I did use the sawn X to keep the drive center from slipping on some large oak spindles I had to turn.
Dick Hines
>I bring the tail stock up to the piece after locking the headstock. Rock the blank back and forth to seat it and tighten up the tailstock again and I am good to go.
>In spindle blanks I cut a diagonal X on the end with the band saw. I actuall stand on the back side fot he blade so I can see the end and cut a slot from corner to corner about an eighth deep.
On bowl blanks I do what Dick does. Gett he blank positioned like I want it and held by the tailstock. With the shaft locked I rock the piece back and forth a few degrees and tighten the Tail stock.
On punky pieces or way out of balance pieces I have been known to drill a socket for the spur, using a forstner bit. A paddle bit would worke too, but the guide center on it goes deeper into the wood and might ruin your blank. This works well if you have bark on the piece also. You can drill through the bark and seat the spur on sound wood.
I also have a home made mallet that is only suitable for seating the spur, because I have used it to set the spur.
Carole Valentine
>I usually drill a small hole for the point of the drive center, then tap it in with a dead blow hammer(plastic coated.) On really hard woods, sometimes after I have tapped it in to show the spur marks, I will use a 1/4" chisel to make the deep indentations for the spurs. I use a 2 spur drive. If the wood is soft or punky, I put a few drops of thin CA in and around the spur indentations to harden the wood and reduce the chance of the drive center spinning. When mounting the piece on the lathe, I bring the TS up, tighten it hard, then back it off just a tiny tad. I have been told that too much pressure from the TS is really hard on the HS bearings.
Re: Seating a drive spur on a natural........
Jamie Donaldson
>.....edge blank is critical, and requires special attention. I often use a 2 blade spur, but drill, hack, chisel down to a solid flat wood surface, excluding any bark. Then make 2 grooves to match spur blades with a cold chisel and mallet before mounting on the lathe. The spur blades should have a start in the chisel marks, then apply needed pressure with quill.
Arch
>No matter how well the spur is seated to begin with, there is often some loosening after the first minute or so of turning so snugging up the tail center is important ...and so is retightening the silly locking knob on my N3K's tail spindle.
Re: I use the tailstock...
>but I have a Sorby Steb centre.
I do the same...
Devon Palmer
>that way if it spins out, its less likely to toss it at you....
George Balock
>Doesn't it depend where your inserting it?
