DEFT clear wood finish
Wolf Kiessling
>I am getting a little tired of finishing my turnings with my traditional Danish Oil finish so, since I am under the impression that Deft Wood Finish is a popular item, I bought myself a quart.
According to the instructions, you are only supposed to apply this stuff with a bristle brush in thin coats so I did that. Did not like the results because I got runs.
I then used a paper towel to apply it on a slowly spinning lathe. Did not like these results either and, besides that, it was difficult to apply. I thought about using this method using thinned Deft but the can said not to thin it.
I am sure that I am doing something wrong because something this popular can't be that difficult to use. Can someone please tell me the best way to apply this product to turnings..........
Re: DEFT clear wood finish
Ken Oakley-Sunny St. Cloud, Fla.
>Most of the time I spray it on with a gun or airbrush. Other times I apply it much like oil stain using a piece of tee shirt material. Apply it sparingly, and wet sand, (400 or 600), it between coats to smooth it and after the final coat I rub it with 0000 steel wool and buff it with a dry soft clothe. For a polished look use a good paste wax on the steel wool, but do not attempt to add anymore coats after waxing it.
Bob Way, Canton, MI
>Like Ken, I use either an airbrush or a lint free rag to apply it. With the rag, my process is similar to a friction type polish. I've not been quite as successful as I hoped to be when I've used a brush or paper towel (especially those blue ones).
Only thing I would add, though, is that I seldom use it straight from the can. Most times I thin it with lacquer thinner. Usually to about 33%, although I've also gone to 50%. Seems I read somewhere that thinning to the 50% level was not a good thing, so I don't do that quite as often as I used to. However, I do seem to be more satisfied with the look and feel of a finish that I've done with several thin coats and a marroon abrasive pad in between coats.
Bob Way
robert davis
>i have used deft for 10 years.thin appx. 10
ihave used deeft for years..thin appx.20% apply with soft brush with lathe stopped rub in with paper towel then burnish with lathe running.then buff with beall system..on more porus woods a second aresol spray coat off the lathe is used before buffing.
5
Carole Valentine
>Wolf,
I use Deft quite a lot, but more to seal the wood before using my traditional Waterlox. I thin it 50%, apply it with a paper towel and immediately wipe it as dry as possible. When that is dry, I buff lightly with 6/0 steel wool and proceed with the Waterlox (number of coats depends on the gloss I want) The Deft minimizes the absorption of the Waterlox and reduces the amount of color change that you get with oil finishes - especially on light woods.
I have used it as a finish, but when I do that I build it in very thin coats (wiped on with a cloth or towel and wiped dry then very lightly rubbed out before the next coat) To me, brushes are useless and I don't have any spray equipment. I also don't like the fumes from lacquer so I use it as little as possible.
David Walser
>I use Deft a lot and like it. The instructions on the can are for flat work and don't translate too well for turnings. (You get runs.) The way I apply the finish is to slather it on with a brush and then wipe it off with a paper towel. Take a quick break and come back to apply another coat. I usually apply three coats, lightly buffing with steel wool (0000) between coats. That usually leaves a nice satin finish that is durable and does not show finger prints. If I want a higher gloss, I apply wax and buff.
David Breth
>I just started using it a little while ago myself. Typically, I apply it while on the lathe, using a small cloth piece rather than a paper towel (after experimentation...). I apply it like Carol mentioned - with a cloth rag, then wipe it off asap. I use a different cloth piece to wipe it off. First pass feels pretty sticky typically, as the excess comes off. Then fold the cloth to a dry side and have another go - ahhhh, now it feels glassy. When the piece comes off the lathe, there is frequently a little bit of streaking, which can be mended by light use of 0000 steel wool.
On some pieces, I apply an additional coat or two off the lathe to use it as a final finish.
Smells like hell though.
David B.
Re: Shelf life of Deft laquer?
Mike Rubes, Apex, NC
>Hi all,
This thread is getting me to start thinking about trying this for a finish on some pieces. I bought a can of this stuff and the thinner about 2 years ago and it has been sitting on my shelf ever since. after that long is it now useless or can I use it?
Thanks,
Mike
Always meant to try it, just never got around to it in Apex, NC...
>I have Deft that is at least 4 years old, I buy it in gallon cans and hit on a sale so I bought 5 gallons, and like other cellulose lacquers I think it has an indefinate shelf live. I have some automotive lacquer that has to be 25 years old and it still works fine.
A little thinner maybe needed if the container wasn't sealed tight
Re: DEFT clear wood finish - Thanks
Wolf Kiessling
>Thanks for the replies. Maybe I'll now have better luck. I will try a little thinning and continue with the paper towel (or cloth) application. I have no spray equipment. This seems to be a case where the manufacturer's instructions are useless..........
Thanks, Ken.
Steven
>Check our Russ's Corner. He describes a method which I have tried and like.
>Wolfe I've been using Deft for a while although I just switched to a local commercial brand. It's cheaper and better I think. To use the Deft I thin it abou5t 50/50 with lacquer thinner. I wipe it on using a piece of T shirt. let it dry a few seconds and then wipe on another coat. If I get streaking I use a little 4/0, rub it down and put on another thin coat. This amounts to a very thin coat that is more satin. I often buff it with the Beal system to get a shine.
I switched to spraying it now. I use one of the $10 HF touch up guns. I still thin 50/50 but have been experimenting with a less thin mixture. This gives me a much thicker high gloss finish if that's what I want. I still put the first coat on by rubbing it in on the lathe.
I've been playing with the minwax wipe on poly and I'm starting to like it a lot. It goes on easily. Builds well, and doesn't smell nearly as bad as lacquer.
Re: I have been using Deft for many.....
Jamie Donaldson
>...years, especially on light colored wood where I want to avoid yellowing. First coat is thinned slightly with a dash(1 glub!) of acetone in a metal can, which I also use for filler/hardener on tearout and punky spots.The initial coat is rubbed in/on with a paper towel(Rags-in-a- Box rule!)and immediately wipe off any excess with lathe OFF. The number of applications varies, and I sometimes use Deft spray cans for final finish, when the kerosene shop heater is OFF!
french pollishing with Deft
Robin Corell in Atascadero, CA
>The manufacturers instructions are so that the product meets various state VOC limits. Depending on the temp I thin to a viscocity that I now know will yeild good flow. to thick and it sags too thin and it takes too many coats
I use a brush on all of my furniture. for lathe work I apply the Deft like french polishing with shellac. I apply with the lathe runnig at the same speed that I do the turning at, Step pullies make me adapt to one speed more often that I would like. I make a 'pad' out of a scrap of old t-shirt. I dip the pad in the Deft and apply to the work, always working from the wet edge. It takes a bit to learn how much to build and how soon to re dip. I have found that if the pad is too dry it will build ridges and if I apply too much at once it takes a bit before I can do a second coat. I do two or three coats then burnish with some wood shavings and remove from the lathe. start to finish takes just under 10 minutes. I build to a pretty glossy finish.
Robin Corell
Re: french pollishing with Deft
Wolf Kiessling
>You mention thinning the Deft in your first paragraph. Do you thin the stuff only when you use the brush application for furniture or do you also thin it when you apply it with a rag to the turning..
>I have used both thinned and unthinned Deft for french polishing it is not as critical as when using for brushing on flat work. I like to thinslightly but not as much as for brushing, straight out of the can will work too.
Robin Corell
