Which grease for lathe bearings?
wilbur
>I have an old Walker Turner lathe that I'm fixing up. I have the headstock disassembled. The bearings seem stiff, but I think that may be because the lathe pretty much sat unused for ~10 years before I bought it. The old hard grease that I've dug out of the headstock so far certainly doesn't look like it's doing much in the way of lubrication -- it had the consistency of earwax.
I plan on using naphtha to try to dissolve/clean out the old grease, then repack the bearings. I'd get new bearings, but these seem to be a nonstandard size, and I haven't found them to be available anywhere yet.
My question is, is there a recommended type of grease for lathe bearings? I'm most familiar with a white synthetic grease that I use for the wheel bearings on my bicycle, but I don't know if that would be suitable for a lathe.
Re: Which grease for lathe bearings?
Re: Which grease for lathe bearings? *LINK*
>The guys in the Machinery Support Services group swear by this stuff. I've used other high temp moly grease for bearings on an old drill press.
Tufoil
Brian Hahn in SW Wisconsin
>My lathe manufacturer (the now defunct Conover Lathes) recommended standard automotive wheel bearing grease. But I normally use a Moly-fortified GL-2 EP grease, mostly because I have it on hand for another application.
