ADVERTISE HERE - FREE TRIAL
Shop made Bowl Steady for Jet mini lathe.
Al Crandall (N.E. of Indy)
>I will be turning at the Wood Working show this weekend in our club's booth. I plan to spend most of the time doing "deep" (9"+)hollowing using my laser guided captured rig. Last year I thought how much better my days would have been if I had only had access to a steady. So since I had two days to spare, I decided today was the day to build one. I glued layers of 1/2" baltic birch plywood together to build the frame.
The arms have 120 degrees of separation, but the pattern is rotated 10 degrees c'clockwise so the laser can track the contour without interferance from the wheel at 9 o'clock. The open frame keeps me from having to "thread the needle" with the laser pointer. The black steel bar spanning the gap at the bottom of the 10" diameter cutout is encased in the frame and goes the full width of the frame. It is 1/4" thick, so in theory this steady would slide under a 9 1/2" turning. With so little capacity, there is precious little to waste. The opening below the steel bar is tapered to fit the sloped sides of the Jet bed; the steady mounts the lathe like a saddlebag. Clamping pressure is supplied by the plywood strip below the frame. It mounts under the lathe bed casting and is tightened by the two wing knobs below.
Re: Shop made Bowl Steady for Jet mini lathe.
Jerry from Lapel In.
>Al great job, I have used the black knobs and you better use lock washers under them. Mine came lose from vibration on my router table.
keith zimmerman, Normal, IL
>Al, I like your solution for mounting the steady to the lathe bed. I have been trying to come up with something to minimize swing loss. It looks like your design solves that.
As I look at it more closely, I may have some questions.
keithz
Allen Neighbors
>Al, it's unique, ingenius, and beautiful. Well thought out design.
Took some engineering, also. :o)
Mark J Edwards
>Al,
I saw your steady at work at Indy on Sat. I was impressed with its design. I also liked the design you had for the hollowing chisel. I would like to try and build both. If you don't mind, I would like to be able to ask some questions about both projects. I downloaded the picture of the steady and was wondering if you might be able to send a photo of your hollowing setup. I was the tall middle aged guy who talked with you from Yorktown. I tried to email you directly but was unable to do so.
Lou Ann
>Al,
I met you at the show too. I would like to thank you, and other members of the club for their kindness and informative answers to all my pesky questions.
(I was the dark headed lady with glasses)
Thanks again.
Re: Mark and Lou Ann, Thanks for stopping by.
>I talked myself silly those three days, but it was a lot of fun. I met a lot of nice poeple and the jigs seemed to garner a lot of attention. Over and over I heard "I didn't know you could do that on a mini." I told a lot of onlookers, "It's called wood turning, not make it as hard as you can make it". I'm glad to do whatever I can to interest more people in our hobby. Thanks to you both.
