shavings
shavings
shavings
washougalmac
>OK here's my question for you,,, What do you all do with your wood shavings... I'd like to burn them but al they do is smolder. Any ideas???
Thanks Mac
Re: shavings
Re: shavings
Pat from MD
>I use mine to cover the path between the garage and the woodpile where I use my chainsaw, since no grass grows there anyways. I've also been told to put them in my mulch beds, and friend with a wood stove asked me for a bag as starter fuel.
Pat
www.beadsandcoves.com
Re: shavings
Re: shavings
Ken Grunke from SW WI
>A horticulturist friend mulches acid-loving plants with shavings--blueberries are what I recall at the moment. To burn shavings, you need some type of mechanical stirrer such as seen in pellet burning stoves. Never had one of those, but once in a while I'll throw a little on a good bed of coals in the woodshop stove but it's not worth the effort unless you have lots of idle time! Effort, in idle time?? Hmmm, would that be an oxymoron? ;)
One thing, you may know already, is that Walnut and cherry shavings are BAD NEWS for horses. Jamie Donaldson, please correct me if I'm mistaken but I think the condition is known as foundering, an extremely painful condition of the hooves. Always worth mentioning every time this subject comes up, which is fairly regular.
Re: shavings
Re: shavings
robo hippy
>I am lucky, I have a friend who said he would take all that I could give him. Some 300 or more bags (40 gal.) and he still wants more. Some of the garden centers will have yard compost piles where they will take brush, grass clippings, etc. Usually for a buck or two per load.
robo hippy
Re: shavings
Re: shavings
Jim Swank
>Down in Arkansas I lived on 7 acres that had lots of low spots. I kept a bag or two of dry shaving which I used when starting a fire in my wood stove. Beyond that, what I couldn't use as mulch went in a low spot. In the Milwaukee area on a city lot, things are different. I can't use as much mulch, and mulch lasts a lot longer. And our little burb doesn't have a composting program. After I had given away all I could at work, I put an ad in craigslist. Hooked up with a guy that did maintenance work at an apartment complex. He picks them up whenever I get 10-12 bags full. Another turner drops his off at a place that does raku pottery.
My main goal is to keep these from going to the landfill with trash.
Re: shavings
Re: shavings
Tom Libby
>A neighbor took some of my cedar and cherry shavings and made big pillows for his dogs.
Re: shavings
Steven Antonucci
Like others -compost, low spots, and burn.
Steve Antonucci
>I have a low spot that isn't so low any more.
I also mulch around trees and garden beds once a year or so.
If I let the shavings lay in the shop floor for a day, I can burn them in a hot fire with no issues. They dry pretty quickly.
No waste in my shop...
Steve
Re: shavings
bedding for horses at local stable
Norm Smith in Nova Scotia
Re: shavings
Dick Hines
Re: shavings
Dick Hines
>I give mine to a friend who has chickens. In return I get a few eggs.
Re: shavings
Re: shavings
>I put them on the front porch in a box wrapped in Christmas Paper. In the morning they are gone. I have no idea where they go.
Re: shavings
My neighbors burn all I produce
Cyril Griesbach
Re: shavings
Re: bedding for horses at local stable
Scott Hurley in N. VA
>Be careful with what type of shavings you give to horse stables. Certain kinds of wood, especially walnut, will cause the horses' hooves to rot from the chemicals in the wood. Horse people (my daughter included) call this 'foundering'.
Scott
Re: shavings
Re: shavings
Allen Neighbors
>Mac, I put them around all my trees, shrubs, grapevines... but not next to the house.
My excess goes to the FAA barn where the kids use them for bedding for animals. And a neighbor uses them to mulch his garden in the spring.
I do not put the walnut shavings with the rest. I toss them in the dumpster, or use them for starting fires in my shop stove.
My wife makes fire starters for our fireplace by putting shavings in muffin paper cups, and dribbling hot wax over them... takes only one to start a good roaring fire in the fireplace.
Re: shavings
Re: shavings
Nailer
>I dump then under our neighborhood playgound set. Especially the area under the slide and the swingset. The long shavings interlock and form a spongy material once it has been wet a few times. After a while the sponge begins to mix in with the soil. I only get to turn on weekends so I produce about 2 55 gal drums worth once a month. It keeps the kids off the dirt and saves our local landfill.
---Nailer---
Re: shavings
Re: shavings
Robert Simmons
>All of mine go into the compost pile. I'll get them back in a while as tomatoes.
Robert
