WE MOVED...
A55 Smoothing Plane
OT-Any Lock Pickers out there?
Jennifer@Indy.USA
>Hey Everyone,
I have a bit of a dilemma here. I bought a scratch and dent filing cabinet a couple of years ago that didn't have a key to the lock. Well Monday my nephew pushed the lock in and locked the cabinet and I can't get into it. Am I going to have to drill this thing out? Anybody ever been in this spot? I haven't tipped the thing upside down to see if there's a way in from underneath. I would assume not.
Thanks for any help on this one.
Jen
Re: OT-Any Lock Pickers out there?
Russ Babbitt
>Yep,,,been there before. I would suggest 3/8" drill bit.
Jennifer@Indy.USA
>You mean there's no top secret magic button on the bottom of the cabinet?
Steven Antonucci
I've picked a couple of cheap locks
Steve Antonucci
>I'd say that you'll probably end up drilling it, but it probably isn't the world's greatest lock, so why not try?
You'll need 2 pieces of steel. One should be tin and flat and inserted in the "bottom" of the keyhole where the flat part of the key goes. On the "top" where the key teeth go, the second L-shaped piece will be inserted and gently stroked across the tumblers. BY applying pressure on the bottom pice, you may be able to pop it.
When I was a kicd, I had a cheap lock that I could open every time with a simple bobby pin. If it doesn't work in 5 minutes, you won't be getting it without a drill bit. Hope for your sake it isn't hardened steel.
Steve
Peter Teubel
>Check your e-mail. I sent you a couple of documents.
I got it! I got it!
Jennifer@Indy.USA
>Okay, I'm feeling really happy and sort of dumb at the same time. Apparently when this place sells these cabinets that have no keys, they already drill a hole in the lock. I didn't realize the hole at the top of the keyhole was not suppose to be there?! When I looked closer at it I could tell it had been drilled and wasn't from the factory like that. So stuck a tiny flat screwdriver in there and wiggled it around and it turned and the lock popped out! The drawers unlocked and now I can get to my stuff!
Sorry for the Drama, but thanks for all the great advice. I sure do appreciate it. I'll know what to look for next time.
Jen
