Seasoning Logs -- Very Long
Brad Vietje
>Allen asked a great question, which is often asked. I started to write a long-winded response, and decided to cut and paste that into a new response here:
There are two objectives here: 1 -- to buy some time until you can turn these, and 2 -- slow the moisture loss to prevent cracks as the wood dries. Both objectives often call for Anchorseal or Green Wood Sealer, paste wax, or equivalent, but don't be confused on this point -- these two objectives are not the same ! It is nearly impossible to dry a log for turning no matter what you use, (short of impregnating the entire thing with some plastic resin, which raises a whole host of other problems), so don't even try. It's fine to store wood for use later, but the wood will degrade a little each day, and will almost always crack if you wait long enough, so eventually you'll need to cut it into smaller pieces, or rough turn it "green", or wet.
Here's the real important part: Objective #2 -- slowing the moisture loss as the wood dries -- is done AFTER the piece is rough turned, not before.
Objective #1. Storing wood to buy some time:
Your best bet is to try to trap most of the moisture in the logs as soon as they are felled by using Anchorseal or a similar product (which I would procure before the trees are cut so you'll be ready). Then process them as needed, or on days when you have a few hours, wack out a number of rough-turned bowls, and re-seal any exposed end grain. The wood will still dry very slowly, and will probably degrade slowly over time (very species dependent), but if you can get to it in a reasonable time, say 3 - 6 months, you can still harvest a good deal of pretty-looking, sound wood without rot. Make sure the wood is stored in the shade, in a cool spot, and away from wind or sudden changes in temperature -- this is FAR more critical than many people think. Usually even Anchorseal won't prevent a Cherry log from cracking if left out in the sun, or if stored in a heated shop.
Objective #2. Slowing moisture loss to prevent cracks as the wood dries:
This is done after the wood is turned the first time, or at least, after relatively thin pieces are sawn for eventual use. I don't recommend sealing a 12" diameter by 6" thick billet, or half log, with any substance, and trying to dry it for turning, and for a whole lot of reasons. Rough turn the bowls or vases or hollow forms, leaving them thicker than the final dimensions desired (usually 10 - 15% of diameter), and then seal the endgrain with Anchorseal or paste wax. For really valuable and fragile woods, you may want to seal the entire bowl, inside and out, which will take longer to dry, but gives added insurance against checks, Many turners seal only the end grain portions, and place the rough-out in a paper bag, which helps slow the drying. These bags ought to be opened every few weeks to make sure you don't get a smelly, moldy mess. Again, these methods are specific to the species in question, and your local climate.
If you live in a very dry area, you may need to store wood chunks where it stays cool or in air conditioned quarters -- Wally's the real expert on this. In damp or humid areas, you need some air circulation to prevent mold and excessive fungal frolicking, but that doesn't mean out where the winds will blow on them, which can cause cracking. New England, where I live, has both conditions, though when its real dry here, it's usually so cold that the wood is frozen solid. During spring and summer its much more humid, and we see a lot of spalt in wood that's been stored through a wet, warm summer.
What I do: #1: I seal all cut ends of logs with Anchorseal, usually two coatings -- see pic, below. I try to get to them within a few months, but if I fail, I try to notice this, and cut the logs along the pith so they can shrink rdaially and tangentially (leaving the pith standing proud). My wood losses are almost all here - not getting to them quickly enough, and I get some degrade and spalting, basically because I have too much wood ! If I don't like them anymore, I burn 'em or give them away.
As for #2, I tend to rough turn bowls in batches -- 8-10 at a time. I chuck them into an open cardboard box near the lathe, and close the box up when its full. The box goes on the floor of the barn for a few weeks, then I look inside, and usually move them to shelves -- again in my unheated barn. The bowls all contribute to a pretty moist environment inside the box, and the cardboard acts as a barrier to moisture loss, like Anchorseal, which I usually reserve for fancy or fragile woods like Apple. For hollow forms, or for bowls roughed out singly, I tend to place them in a paper bag, and store down low. near the moist floor of the barn, and I check these every few weeks.
If you have logs or blanks that have tiny cracks in them, Anchorseal won't save them. If you try to dry a full-diameter log, well, you just won't live that long, and it will crack anyway. Don't fear green wood turning -- get Michael O'Donnell's book, called Turning Green Wood, and have at it -- it's fun.
Photo shows some medium-sized Butternut logs coated in Anchorseal, which goes on white, and dries clear. These were coated within 5 minutes of getting them home, and Butternut is a fairly forgiving wood. Get the Anchorseal before you go collect your logs. I often coat them "in the field", right where the tree is felled.
Safe spinning,
Brad Vietje
Newbury, VT
