WE MOVED...
i finally did it
i finally did it
i finally did it
jared
>remove xx for email
Well i finally did it and just had to tell somebody. I have been turning for about 5 years. I started out on a delta midi and then two years ago got the 3520. When I started out on this obsession, I would read on these forums about turning until you could start sanding a piece with 220 grit or whatever and I could never understand how you could do that. My bowls were always rough and torn out and it took a lot of work with the 80 grit to even start with Well today I turned a shallow bowl, 12 inches in dia. and with some carefull shear scraping, I was able to get it smooth enough that the 220 grit was entirely adequate. The wood is ash. Just had to tell somebody. Jared
Re: i finally did it
Brad Vietje
Atta Go, Jared !
Brad Vietje
>I have to admit, Ash is probably not the easiest wood to achieve the 220 grit, off-the-gouge finish, but good on ya ! Now try Cherry or hard Maple, and you'll be one happy fella.
Safe spinning,
Brad Vietje
Newbury, VT
>Way to go Jared. I've seen Stewart Batty turn something with his 40 degree bowl gouge. He sanded one side of the piece to 400 grit and turned the other side with no sandpaper. You couldn't tell the difference. I'm not there yet but I thought I'd give you something to shoot for.
Cool! :)
Jennifer@Indy.USA
>I'm afraid I still usually start under 220 :(
I'll just chalk it up to more one on one time with each bowl :)
Jen
Re: Cool! :)
Ken Grunke from SW WI
>Man, it sure does feel good when you reach a point of figuring out a technique like this. There must be a term to describe it--quantum leap maybe? That's my vote. Congratulations, Jared!
George Van
>I gotta go with Brad Jared. Ash is a difficult one to finish that well off the gouge. The denser more even hardness grained woods will be a "piece of cake".
Allen Neighbors
>Congratulations, Jared. I've tried several times, but have never been able to start sanding with 220Grit. I think it may have something to do with my built-in tremor.
Maybe someday.... sigh....
