We value your privacy.
>I found the resin I think I'm looking for.Unfortunately the maker has a very limited selection of dyes,I'm loking for an opaque white dye that will work with casting resin from Michaels.Any help will be appreciated..Thanks,Rick
>I haven't thought of inlace as a coloring agent..Nice link and beautiful work there. I see they do have opaque dyes and I know the inlace product is bondo like in texture,how well will it work with a very runny liquid such as the casting resin? I plan on casting around pink ivory/african blackwood and don't want to chance ruining it..Thanks,Rick
Inlace isn't anything like bondo at all. Inlace is a 2-part resin that is mixed together and poured. Different materials are added to it to make different colors and effects.
>Inlace is a 2 part polyester resin and hardens to about the same density as Corian. One problem I've run into with other casting mediums is the density of the medium. Some things that you put into the medium will float, some sink and some just sit there. Inlace has the right density to suspend the smaller particles.
I have used Cast-n-craft and System 3 mirror coat and some materials that you stir into it will sink to the bottom. Mirror coat becomes very viscous as it cures and will actually run through the pores of some woods.
The only problems I've had with Inlace are air bubbles. Sometimes you just can't get rid of them so I fill them with CA glue if they are on the surface. The clear Inlace usually dries bubble free unless there are bubbles trapped under something that try to escape as the stuff is hardening.
