Woverine sharpening jig
C.W.Stivison
>Now that I have been turning for 3 days I have found out how important sharpening is. Is the Woverine jig a worthwhile investment or is something else a better solution for a beginer.
Thanks
C.W.
C.W.Stivison
Thanks
C.W.
Re: Woverine sharpening jig
Greg Haugen
>In my view, its worth it. I would go with the base system and a varigrind. The skew jig I don't think is a big help, that is pretty easy to platform sharpen. The dresser I don't like personally, I prefer a "T" style dresser, they are also cheaper. Others may tell you to go freehand sharpening or platform sharpening for everything to learn sharpening. That's what I did, and don't know if I would recommend it. You can still do that, the platform is great for that but if you get too out of wack you can throw it on the jig and get it straight again. There is no shame in using a jig. It will save on your tools and shortens the learning curve. There are other options, kelton makes one and others. Oneway's is used the most I feel and is the best for all around system. It is also easier to find accessories.
just my thought on it.
Greg
>I'm also a fan of the Oneway sharpening system with the Wolverine jig and I also like the T diamond wheel dresser that I get from woodcraft for about $15. The Oneway system isn't cheap but I think it really saves your tools and helps you get skilled at sharpening quicker. It isn't fool proof. You will still have some problems but we can help you solve them.
Russ Babbitt Jr.
>I also go for the Wolverine. I have the complete system but would recommend the base system, the varigrind, and the diamond dresser. I also use the T diamond dresser for everyday cleaning of the wheels, but every so often I use the Wolverine dresser to keep the wheels round and balanced. You can keep the wheels in round with the T type dresser as long as you keep a light touch and prevent any bounce of the dresser.
David Walser
>You may also want to consider the Woodcut's Tru-Grind sharpening jig. It can be a little cheaper than the Wolverine (but which costs less depends on which is on sale). The main advantage of the Tru-Grind is that it takes up far less space than does the Wolverine, allowing your grinder to be set closer to a wall. The downside for the Tru-Grind is that it MIGHT take a LITTLE longer to set up for each use. (Unlike the Wolverine, which just uses a "v-block" to grind roughing gouges, the Tru-Grind system requires each tool to be mounted in its version of the Vari-Grind.)
You can see the Tru-Grind by following this link: Tru-Grind
David Walser
>Can't you also use the T-dresser by mounting it in the varigrind? That's how the Tru-Grind system by Woodcut works.
Russ Babbitt Jr.
>The Wolverine works to keep the wheel round because it is held a fixed distance from the wheel by the round rest of the dressing jig. If you hole the T dresser in the vari-grind it can still bounce. It's a neat idea though.
Russ Babbitt Jr.
>Boy I wish I could go back and correct my spelling. Hole is hold.....
Bruce Wiseman
>If you are long on time and short on money there are many plans around for building your own sharping jig. Most of the ones I've seen do everything the Oneway stuff does. I know David Ellsworth has published some and I think Ernie Conover also has. Maybe a google search or hit the archive here on WC?
David Walser
>Yes, if the wheel is out of round, holding the T-dresser in the varigrind jig will cause the dresser to bounce -- until the T-dresser gets the wheel into round. At least, that's what I think is happening when I use the Tru-Grind's T-dresser in the woodcut's jig.
Barry Turner
>In my opinion, the Wolverine system is as good as it gets when it comes to sharpening jigs. You can't learn to turn well, until you learn to sharpen well. Sharp tools are essential. The quickest, easiest way to sharp tools is with a Wolverine jig or some other equivalent jig.
Some will tell you to go with the Tormek system. They are entitled to their opinions, but the Tormek is just too slow for most people and I'm not convinced of the advantages over a good dry grinder and Wolverine jig setup. If you wanna spend your time sharpening, get a Tormek. If you want to maximize your turning time, get a dry grinder and jig.
C.W.Stivison
>I knew I could count on my new best friends for some good advice.
Thanks
CW
Re: The Woverine system also .....
Jamie Donaldson
>...includes an excellent tool rest, and I've never seen a good rest that comes standard on any grinder. With the price of HHS tools these days, a good jig system like the Wolverine is a nobrainer!
Joe Flemig
>I have the complete Wolverine system and it is a fine sharpening tool. I have also used the Tru-Grind and like it.
I recently acquired the McNaughton system and it has a couple of notable advantages. One is that the table is notched to go around the wheel. This is really handy when sharpening the side of a scraper. You get tool rest support on all sides. Second is that the table's front corners are round; not square. If you freehand sharpen a tool that requires the tool to swing around the wheel (arcing across the table), a shorter tool's ferrule will hit the corners of the Wolverine. Not so with the McNaughton. Finally, the Varigrind jig depends on the flute of the gouge to register the tool. The McNaughton can work with the flute or a round bar equally well.
Joe Fleming
Re: Wolverine is the one I went with,
Allen Neighbors
>and I love it. I have the Oneway balance system for it, too.
Joe, I realized I needed my toolrest to wrap around the grind wheel, not long after I bought my Wolverine Setup. I marked my toolrest, using a square, and ground a 3/8" deep notch for the wheel. It's 1/6th inch wider than the wheel on both sides. Works well for my Oland cutters, especially those that I sharpen along the sides.
Doug Thompson near Cleveland
>I believe you have the only answer Lol Most everyone owns one because they work... plain and simple. You found out a sharp tool makes all the difference in the world.
