another option on dremel carrage
Norm Smith in Nova Scotia
>This is a cheap drenel type tool ($10.00) epoxied to wood cradle and screwed to plastic sled. The table is adjustable up and down and is level. The dremel tool can be centered by adjusting the elevation of the table using the bur in the tool and the drive center. The table can also be adjusted up or down by holding a square to the live center. For larger V groves I use a laminent trimmer. It has a block epoxied to it and than is screwed to a plastic sled. I have been using this system for a few years and have found it to work very well. The Ttable is a piece of counter top attached to a 6" face plate with a 1" bolt (head cut off) screwed in , that fits my banjo.
See other pictures
Re: another option on dremel carrage
>Excellent job norm. I use the same laminate trimmer. I've thought about putting formica on the top platform but I waxed the top and it's been working fine so far.
Wayne Allen - Carson City. Nevada
>Norm -- Thanks for the pictures. This is a real help. --- Wayne
>Thank`s John, I have made modifications over the past two years and have found that this works best for me, whereas it may not for others.
Norm
