Question on those Cane "Joins"?
>A client asked me to make some canes. He provided the walnut and the hardware. Those brass Tee handles and the fitting that allows the cane to break down like "a two piece custom pool cue".
I made some with varying luck.
Does anyone have a proven technique for drilling the blanks? I tried the drill press, but found the bit wanders a little. So I drilled the blanks first and then turned them. Found the threads on the fittings cause the fitting to be slightly off center.
Now I am trying one where I drill and mount the fittigns on the
blank and use it to chuck the piece in the lathe. Another question. If I move the "other" end slightly on the tail center, won't the cane be crooked?
I'm thinking I need to drill and mount the fiting and then chuck it so that the tail center is in perfect alignment with the fitting and so that the fitting is perfectly "vertical" in the piece.
Re: Question on those Cane "Joins"?
Re: Question on those Cane "Joins"? *LINK*
David Breth
>You are on the right track with drilling/fitting the hardware first. Mike Cunningham sent me directions from the attached link when I was struggling with it. The link takes you to the Woodturner's catalog, where instructions are provided. Look up Walking Stick - apparently "cane" and "walking stick" are synonomous. Even with the directions, it took me awhile to sort out what to do first, next, last, but these definitely helped.
I've done one cane, and did end up with a situation where the bottom third veered slightly away from true. A little bit of wobble, a little less than an ideal tenon, whatever the error can go a long way with these.
Hope this helps.
David B.
http://www.woodturnerscatalog.com/catalog/instructions.html
