New hoist over my lathe.
Al Crandall (N.E. of Indy)
>A short time ago I asked the board for solutions to the problem of getting heavy wood from the floor to the lathe. With your help and a lot of help from my good friend Jerry near Lapel I now have the rig pictured here. The supports are a 4x4 post which is anchored to the lathe at the headstock end, and an A-frame support which rides on locking swivel casters at the tailstock end. I can easily move the loaded hoist or the A-frame with two fingers. It is less than 88" tall, so it clears the tracks of my overhead door which is near my lathe. The picture shows it sitting over a lathe other than mine, but it will soon be moved to my shop and attached to my lathe.
Re: New hoist over my lathe.
Terry Quiram, Roanoke Illinois
>Al
Nice solution, I couldn't do that I don't have room to swing a cat.
Terry
>Al I've been thinking about hanging the kind of rack used for hanging a barn door over my lathe. The problem is I would have to move the lathe so the headstock was inbetween my two garage doors. It would be similar to your idea.
George Van
>Great idea Al, I do not know where you find the time to get so much done. Perhaps I need lessons. Thanks for posting.
adrien
>We turners have to be as nutty as golfers!
>Impressive, of course.
Rated at what, 2,500 lbs.?
Planning on lifting just wood, or are you going to start spinning that nice Indiana Limestone?
Re: Looks like it'll work!!
Allen Neighbors
Re: That sliding door hardware is buried inside
>That sliding door hardware is buried inside the two 2x6 which make up the beam you see in the photo.
Re: Priorities, George. Fun always comes first.
Re: I went cheap on the hoist. Only 880 lbs rating
>I think the weak link is the sliding door hardware and track. It is rated for only 500lbs. But you oughtta see how slick it can remove and install that 62 lb tailstock without straining a muscle. This may obsolete my tilting tailstock jig thingy. The Indiana limestone can stay down by my favorite winery. I'm not totally nuts, you know.
