Dremel carriage
Dremel carriage
Dremel carriage
>Here is the carriage I made for the Dremel. It's sitting on my new adjustable router platform.
Re: Dremel carriage
Re: Dremel carriage
>Here is the Dremel carriage itself. I turned a hole in a 2x4 and then cut it in half. mounted it on a piece of 1/2" ply and it was ready to go. I will add a depth control plate to it later.
Re: Dremel carriage
>After building my first 2 router platforms I decided that I needed a sort of micro adjustable router table so that I can change the height above or below center when necessary. I took a piece of All-thread and cuat it to lenght. The I took a pipe flange that was 1" and re-tapped it to 1"x8. I welded this together. I'm going to put marks on the Nut so I can tell exactly how far it's moved so that I can adjust it by 1/8th of a turn.
Re: Dremel carriage
Re: Sometimes I think you have more...
Jamie Donaldson
>...making and playing with new toys/tools than actually using them!!!
Re: Dremel carriage
Re: Dremel carriage
John Uteck
>Thanks for the idea John --- I was thinking of something similar for mounting a woodburning pen. I hadn't thought of the 1" allthread -- I was planning on the 3/4" pipe flange and a piece of 3/4" black pipe filed down to fit my banjo.
Re: Dremel carriage
>Jamie Most of my toys are designed because a project needs them. I've been doing a lot with the router lately and this is the latest step. This was done to see if I can improve on the "brick" making pattern I've been doing. I've got to get it just right before the big project which is still in the design phase.
Re: Dremel carriage
Re: Dremel carriage
>John I was wondering if 3/4" all thread would fit a 3/4" banjo. Let me know because I'm doing another router class in february in Memphis. I'm going to try some smaller stuff in the Jet mini banjo.
Re: Dremel carriage
Bill Crommett
>Isn't that the way it is supposed to be ?
Re: Dremel carriage
Re: Why not adjust by 1/12th of a turn?
Al Crandall (N.E. of Indy)
>Hi John. The nut already has twelve markings on it. It has 6 corners and 6 flats which are fairly short in width. This short distance is easy to interpolate the center of. Put an index mark on the banjo and you can read the height change of the platform in approximately .010 increments as you twist it from one corner to the flat center to the next corner to the next flat center....
Your screw is .125 per revolution, so why not read in 1/12 increments?
Re: Dremel carriage
Re: Jet mini banjo uses 5/8 tool rest post.
Re: Dremel carriage
Re: Dremel carriage
John Uteck
>John -- the 3/4" black pipe is just over 1" OD. It is too big as a 1" post on my banjo -- thus the need for filing it down. Likewise, 3/8" black pipe is 0.675" OD ---- bigger than the 5/8" tool post on the mini lathes.
To use allthread on the mini lathes with a 5/8" diam. tool post, I'd suggest the 5/8" all thread, with a 5/8" nut cut and epoxied into your wooden platform, or even a long 5/8" bolt with the head inserted into a cut/drilled hole, and epoxied into the platform. You could make your own flange by cutting a hex-shaped hole in a wooden "plate" using a scroll saw, to fit the nut/bolt head, and if needed to give it more stability, sandwich the bolt head between layers (i.e., make the support 3 layers thick -- the top layer would be your solid table, the middle layer would have a hex hole cut to fit the bolt head, and the bottom layer with a 5/8" hole for the bolt to pass through).
Re: Dremel carriage
Re: Or use a 5/8 carriage bolt.
>Drill 5/8, counter bore with a Forstner bit to recess the carriage bolt head, and tighten a nut and washer on the bottom side. I have used thin CA glue to reinforce the square depression left by the head of a carriage bolt so the square won't strip out.
Re: Dremel carriage
>Al I figure you can actually adjust it as fine as necessary. I do need to create some friction on it so that when I remove it from the lathe the nut stays put. I think I'm going to drill and tap it for set screw and put a nylon pin in front of the screw. I thought about using one of the locking nuts but I'm not sure I can find a 1"x8 with the nylon lock. I'd have to run a tap part way through to make the less of a locking nut and more of a friction nut.
I thought about milling a slot in the all thread so that it would stay aligned but then I'd have to add a swiveling lock at the top because you do have to align the table with your project, depening on how you set a depth adjustment for the router. I usually use a homemade fence clamped to the table.
Re: Dremel carriage
>Excellent ideas guys. One of the problems is keeping the table aligned so it's parallel to the drive centers. Since I was off a hair after welding I glued a wooden shim to the front surface and then trued it up on the lathe.
Re: Dremel carriage
John, make your own locknut by...
Clem Wixted, Jonesboro, AR
>...by drilling a hole through the threads on your nut the size of some heavy string trimmer line. Push the string through both sides of the nut and let a little stick past the threads inside of the nut. When you force the nut past the line it will give you some pretty good friction. You could put 1, 2 or more points of friction by drilling a hole for each one.
Clem
Re: Dremel carriage
Re: Locknut
>John,
1x8 is a standard thread. McMaster has the nylon-insert nuts in that size. Part No. 90640A360 For the cost of the time it'll take you to make your own, you and she can go out to dinner.
mm
Re: Dremel carriage
PS
>If you changed your rod and nut to 1x12, that would give you a finer adjustment just using the hex points, no?
mm
