Makore vs Bubinga Wood
E Tabachek
>Hello, Is Makore wood anything like Bubinga wood? Color? Texture? Fancy grain? Hardness? I was given a piece of makore that looks like what I have purchased as bubinga.
Thanks for any help, ET
E Tabachek
Re: Makore vs Bubinga Wood
Ron in Drums PA
>Makore is also known as African cherry
Bubinga is also known as African rosewwood
They are different woods
Steve Kubien
>Can't tell you anything about comparing these two woods. Here's what I can tell you...Makore is the first (and so far only) wood that I've had an allergic reaction to. I've turned rosewood, cocobolo, wenge, and a decent number of common stuff but the makore gave me a burning feeling in my nose that would not go away for hours.
***Graphic content here... Kinda like that feeling after you throw-up and some comes out your nose. Not nice.***
I found this out while not wearing a mask under my face shield and truing up a plate. I wasn'teven sanding it! Second time I put the mask on which helped but not 100%.
Play safe,
Steve Kubien
>The makore I've used has ranged from really "red" to red brown. The bubinga that I've used has been more brown. The grain on the bubinga seems tighter.
BEWARE of Makore
Mike Schwing from Md.
>By far, Makore causes more respiratory distress than any other wood with which I have come into contact. Just a whiff of it will cause me to cough, sneeze, drip, etc.. for quite some time. It also gives me contact dermatitis (rashes) anywhere the dust settles on the skin. I won't use it again, but it does produce some startling work.
Bubinga - I could eat that stuff with no problems. Wonderful working properties, too.
Here's a table I built a while back from makore:
Bob Fawcett
>They are not much alike.
Bubinga is very dense, very heavy, and hard.
Makore is less of all 3.
Bubinga is a darker color and more red. Makore looks a lot like American Cherry in color and texture.
They both turn nicely.
Bubinga polishes better than Makore.
