Re: Lathe not turning 'true'
Stephen Gehres
>OK. If I'm reading this correctly, deviation is normal when the tailstock is not brought up to even touch the end of the mandrel? I've taken the rods out of all three mandrels and they roll on a flat surface like they are perfectly flat/true. I guess they could be off by a few thousandths and I wouldn't even notice it with the naked eye. But when I put that same flat rod back in the mandrel's MT (without pulling up the tailstock) and the wobble is 0.032", it makes me wonder why.
When I bring up the tail center to just seat into the end of the mandrel, are the deviations I'm getting normal? I never measured the first model before returning it, but the blanks were really crappy after they got turned. There is a difference of 0.013" in the wall thickness of the blank from one edge to the other (one spot is 0.038" thick, and another is 0.051" thick).
Here are my responses to what y'all have mentioned:
> As mentioned, too much tail stock pressure will cause your mandrel to bow
I'm just barely seating the tailcenter's cone into the concave in the end of the mandrel. For my measuring I had *NO* pressure on it at all.
> also a common problem is over tightening the thumb screw or nut on the mandrel.
When doing my measuring, I didn't have blanks, bushings, or the thumb nut on the mandrel.
> Once you have your blanks rounded, back off the pressure and rotate each half 180 degrees.
I'll give this a try when I turn a couple test blanks.
> One last thought, do your mandrels require a 60 degree live center in the tail stock?
I have no idea. The manuals are always very lacking in details.
> Move the tailcenter up to the drive center so they almost touch. Be sure and clean both morse taper surfaces before inserting the centers. Then rotate the drive spindle by hand. It should stay pointed at the tailcenter without rotating in a circle. The two centers should also line up.
As far as I can tell using my magnifying desk lamp, both centers are almost touching and seem to be lined up just fine.
>But if the deflection out of round and at the live center is that much I would suspect the live center point may be bad?
This is a brand new live center and the point is still perfect.
Someone emailed me directly and one point they made is: "My personal opinion is if you have a lathe that will not stay in adjustment and/or run true, the frustration will be terrible. You will either get discouraged and quit, or spend more money on a better lathe." That sums up my past couple weeks. I've been VERY frustrated. For the extra $90, the Rikon might ease some frustration... Or might I end up fighting the same problem???
Still open to suggestions...
Thanks again,
~Steve
Spunky-Monkey Woodworks
stuff@Woodworking.Spunky-Monkey.com
