Which pen finish to use?
ben borowsky
>I'm looking for a shiny, durable pen finish. I've tried PPP, behlens, and a few others without much success. I also tried Hut Crystal coat... (Using CA glue was a spectacular failure...)
What do you use? What can you suggest? Thanks in advance for any thoughts you might have.
B2
Re: Which pen finish to use?
ScottS
>I typically use CA glue and Myland's Friction Polish. I typically sand to 600 grit on the lathe. Then I apply a thin layer of CA, especially if using a burl or other "punky" wood. Then I start at 600 grit again and sand to 2000 grit, still on the lathe. A single coat of Myland's Friction Polish tops things off. I think the finish left by the Myland's is better than Hut Crystal Coat, which I've also tried. I've also tried PPP and been disappointed. Multiple coats of Myland's doesn't seem to work as well as a single coat, FYI.
For acetate pen blanks, I sand to 2000 grit on the lathe, then polish with Novus #2, followed by Novus #1 both done off the lathe.
Both of these finishes are very quick and seem reasonably durable.
eaglesc
>Look to the right hand side of this page and see "Russes Corner"
There is a wealth of information there about finishing pens and watches.
You could also check out his website http://www.woodturnerruss.com/Pen10.html
Some like CA, some like just a wax, some like shelac, some varnish, some urethane, some even use plexiglass dissolved in acetone. I prefer lacquer.
The easiest, most durable, fast, best looking pen finish is the Holy Grail, for most pen crafters.
Try them until you find the one you like best.
eaglesc
>I mean the other right. The hand with the jewelery.
Some call it the left.
(Dyslexia rears its' ugly head)
ben borowsky
>Thanks to both of you, and also to Russ for writing that detailed treatise. I appreciate it, very much.
B2
