We value your privacy.
>I forgot to ask a question. I made some of the bowls similar to Micheal Mode, a long time ago. I had an article by Mike Schuler from Finewoodworking but I've apparently lost that article. I can't remember the angles. My first test on a scrap piece was not quite there.
I used to draw these things out to figure the angle but I'm having trouble making it work this time around. Does anyone know the angles that work. I've got the boards all glued up so now I'm ready to use the bandsaw or scroll saw to cut the rings. I just need to figure out the angles.
I have that information somewhere but it is time for me to spend the night at the workplace.
The angle you need is dependent on the thickness of your wood and the kerf thickness of your cutter to begin with so my angle guide may not be of use to you, I do this type of work on my ringmaster which uses about a 1/8" cutter.
I have only made one straight like your reference and usually go to the paper plan or use my ringmaster design software which tells me the angles.
If you don't get an answer by morning I'll see if I can help!
>Thanks John I tried to take a reading off the photo and it looks like around 60 degrees from the bottom which would be 30 degrees from the vertical plane. That's not far off your 22 1/2. If I get time I'll run another test tonight.
I'm going to use the scroll saw so I don't have to reglue the half rings. I've also done this sort of thing by cutting the rings using a thin kerf parting tool and cutting the rings on the lathe. In that instance the angle didn't matter because I cut a whole bunch of rings out of the same material and just stacked them so they looked good.
>John, UR not foolin me are you, although I haven't used my ringmaster in quite awhile I know I would be in trouble being off a half a degree, it just won't come out right for sure. The last time I did a project on it I made the mistake of not checking the thickness of my stock and it happened not to be the same as the scrap I used to check the angles, scrap aligned, good rings did not!
>John That was the advantage of using the same wood and just cutting lots of rings. I just eyeballed the angle and used thin parting tool that is about 1/16". When I was done I simply picked through the rings until I had the ones that would stack on top of each other to give the shape I wanted.
I used 3/4" wood but I would make a part in from the outside at the 3/8" mark and then part it off from the front. This gave me something like 20 rings from a 12" x3/4" board.
I made a 3 foot tall tornado for our clubs entry into the AAW club competition. This one didn't have to be turned afterwords so I could stack the rings to give me the offset funnel cloud look.
I've never tried this sort of laminated bowl, but your post reminded me -- the very first woodturning meeting I ever attended was in Michael Mode's shop -- what a treat ! At the time, I didn't even know who he was, or that he was already pretty well known for these elegant bowls.
I do know that the example shown on the link above is a very simple one of a checkerboard pattern. Some of his bowl are a lot more complex, and he's done a lot of drawing and figuring to achieve swirls and curves that extend through all the layers. Beautiful without a doubt, but too much paper & pencil, and not enough turning for me.
Here's a pic of Mike showing his method on a simple form at a meeting of the Vermont AAW affiliate -- The Woodchuck Turners of Northern Vermont.
>Here's a close-up of Mike's custom-ground finishing gouge. He uses this tool, flute up and left side cutting nearly vertically, to produce a finish cut on the inside of these very delicate bowls, which taper from about 1/16" at the rim to less than 1/8" near the base. Pretty incredible.
