Finish for pens
C.W.Stivison
>I am going to turn some pens and would like some input on what kind of finish some of my new best friends use.
Finish for pens
C.W.Stivison
It Depends.....
Jim Shaver Oakville, Ont.
>Hi C.W.
Well the finish I choose for a pen depends on the materials the pen is made from, at least for me. There are as many finishes and processes for pen makers as there are pen makers, so I hope you get lot�s of responses from pen makers to your post.
When I turn natural woods I sometimes use just a friction polish and wax, occasionally I will use CA as a finish, even lacquer. When I turn man made materials I usually just allow the materials properties (plastic, acrylic etc) to be the finish, sanding to 12000 Micromesh with a final application of a plastic polish to clean up the final swirl marks. I most commonly turn stabilized woods, I also use the same sanding process I use for man made materials and I finish with a conservators wax from Lee Valley.
Surface preparation all starts with the final pass of your turning-cutting tool of choice. I look at sanding as surface refinement, not shaping. I find the cleaner surface of tool marks that you start with at the sanding phase the better the result you will have. I know you will find that a good starting point, honing your turning tool one last time before the �Money Cut� will give you a great start.
Take care,
Jim
Re: After much expermentation
Terence Rice
>I use 2-3 coats of CA glue, smooth with 0000 steel wool and use Hut friction polish. It is fast, easy and durable.
Re: Finish for pens *LINK*
RiccoG
>Hi CW You can try Russ" Corner on the home page or go to his website
He has a good site, and he has DVD's about pen turning ad finishing. I purchased 2 in Dec. they are very helpful.
Re: Finish for pens
RevDoug
>Sand to 2000 and then one application of EEE paste and 4-6 applications of Shelawax. I used to add an application of Beeswax but now will allow the pen to rest for a few minutes before I assemble and will then take it to the Beall buffing wheels for a carnuba wax finish. Hard to beat.
Turn 'em round,
