large tap
large tap
large tap
Frank of Mantua NJ
>I am looking to find a used 1" X 8 TPI Tap I want to make some wood face plates and other items I saw. But a new tap is not cheep, I have been looking in flea marts ect with no luck
Re: large tap
Re: large tap
C Yawn
>Frank, I am looking for one of these also to make wooden faceplates. I'll monitor what others respond. Just a thought; we might can make an arrangement to share the cost of one of these taps. I expect I can make a bunch then not need the thing again for years, so sharing make make sense. Charles
Re: large tap
Ace Hardware
Bob Elliott
Re: large tap
Re: large tap
C Yawn
>http://www.jlindustrial.com/catalog/product.jsp?id=TAP-15146C&origin=SEARCH:KEYWORD&backtosearchpage=Y
As a follow up, I just found this site that has the tap for about $22. That's cheap to me. Charles
Re: large tap
Re: large tap
>Frank I looked at all of my resources including my local bearing supply house. Enco's Price is the lowest I found. Fortunatly I found one at the flea mkt this summer. What I need is a 1 1/4x 8. Try to find one of those cheap. I haven't found one I could afford yet.
Re: large tap
Re: large tap
Juergen
>I bought mine in Ebay, you just have to be patient. Frquently no one bids on these because outside of the wooturning community that is not that common a size. That's particularly true for the 1 1/4"x8 size. What is really hard to find is a 1 1/8"x8 left hand for the outboard spindle on the big General. Good Luck
Re: large tap
Yo Frank....How about this one.
Michael Stadulis, in Gloucester County, NJ
>http://www.bealltool.com/products/turning/spindletap.php
Best Regards,
Your buddy... a few miles west...
Mike
Re: large tap
Leo Van Der Loo
You could make one yourself, to cut thread in wood
Leo Van Der Loo
>Get a bold and 2 nuts, turn the nuts on to the bold, making sure the last nut is even with the bold end, place the assembly in the vice and tighten the nuts up against each other.
Clamp the bold and nut assembly vertical in your drill press and locate the bolt so that you can drill a hole down through the centre of the threads.
Drill 4 holes as far as you want/need, (3/8" D) take the nuts off, relief file the threads on the bolt with a narrow 3 point file, and you could taper the end some with a file, easier if you can turn it in your lathe while filing, you should do this before relief filing the treads.
Sharpen the treads with a small cylindric stone, ball stone or fine round file.
A tap like this will work for making threads in wood.
Have fun and take care
Leo Van Der Loo
Re: large tap
Re: You could make one yourself, to cut thread in
Earl Kennedy
>I have made a 1" 8 tap out of a bolt.I just take my 4" edge grinder and grind 5 groves length wise in the bolt.Grind a little deeper then the threads.I also relieve the threads on the trailing side of the threads a little.You might file the leading edge of the threads but I bet it will cut nice threads right off the grinder.I drill a 7/8th hole and use a impack wrench to run the tap in.You will need to use a pull bar or a very long handled wrench to thread hard maple.I also use the thin super glue on the threads and then run the tap in it again.I have found that I haft to run the tap back in after a few day because the wood moves.The more groves in the bolt the better it cuts the threads.Try this at your own risk.
Re: large tap
Brian Simmons, Heflin, AL
>A few of thoughts, buy some nuts at Lowes and epoxy them into your wood blanks. Another method especially for the left hand thread is something I have done for left hand metric threads that were around 1.5" in dia. I found a wire that fit well in the thread, I wound the wire around the thread, I measured the outside diameter of the wire wrapped thread, I bore a sleeve to match this diameter, I slid the sleeve over the wire and tacked the wire to the sleeve, Not a long term solution but if you need it once in a while it would work. Another option might be to coat a bolt of the same size with vaseline or some other release agent and cast the nut/threaded section you need out of JB weld or even a thin flowing epoxy, unscrew when cured. Good luck
Re: large tap
I bought this one: 1-1/4�8 #1-372-420 $43.85 from
Al Crandall (N.E. of Indy)
>www.jtsmach.com
They were a lot cheaper than other suppliers.
Re: large tap
I searched the WEB *LINK*
Bob Fawcett
>a few months ago. I don't think you can find spindle sizes cheaper than Beall Tool.
Taps
