Queestion: Mounting grinder wheels
Chuck Engstrom
>Hi folks -- I have new pair of grinder wheels. What is the trick to getting the opposite-threaded nuts on each with sufficient tightness? There's no excess shaft thread to play with, no flats on the inner portion of the shaft -- whatever I do to tighten one end loosens the other.
There must be an obvious trick to this that I need to be coached on.
Thanks--
Chuck Engstrom
Chestertown MD
Re: Queestion: Mounting grinder wheels
Ron McKinley
>Take a piece of 2" x 4" or other scrap and cut it into a wedge shape and stick it between the top of the wheel and the top of the guard. Then tighten the other wheel nut.
Gordon Seto
>Don't worry about them coming loose. As long as the grinder is not running in reverse (it can't); the wheels are self tightening.
Gordon
Russ Babbitt Jr.
>The wheel nuts should be tightened just enough to keep the wheel from slipping when the grinder is on. Overtightening can damage the wheel. If these are new wheels do the "ring test". Support the wheel with a pencil or suspend from with a piece of string. Lightly tap the wheel with a screwdriver handle. You should hear a nice ring. If you hear a thud the wheel is likely damaged. Also when starting up the grinder for the first time stand to the side for about a minute.
