HVLP Conversion Guns
John Scheideman
>I, too, am in the market for a HVLP spray gun. I don't want a turbine and have seen the Apollo "Atomizer" gun on their website. Can anyone tell me how it would compare to a Binks conversion gun? I have used a regular Binks gun for years and it is an excellent gun but I'm tired of the overspray! Thanks for any help.
John
Re: HVLP Conversion Guns
nailshooter
>I am sure you will get a lot of opinions here - all good. But my personal experience is that once you get beyond a certain price point, they all shoot pretty well and it really comes down to which features you want. I wouldn't be entirely concerned about the brand as long as I had heard of it and could find some internet opinions on it.
I would look for a gun that can shoot gravity or pressure fed (pot/can). The next thing I would do is find one that has the different aircaps and needles you might want to shoot different finishes. When I shoot dyes, I use a 1mm aircap. Following up with lacquer, I use a 1.4mm.
My personal experience is that my high pressure guns (which seem to be the most fail safe) have the most overspray. >>When adjusted properly<<, the conversion HVLP has less, but maybe in the 30% range.
My turbine has the least, and again, when adjust properly (including the finish itself) it is amazingly small.
To put a point on that, I was at a woodworker's show in Houston last year, and the Turbinaire and Apollo reps both let me shoot their HVLP turbine guns in the middle of the convention floor while it was in full swing! I went was overwhelmed... that meant I could do refinishing and finishing for my clients in their garage! Sold!
Came home, researched, bought the Fuji Q4 system and haven't looked back. I still use the other guns, but not near as much. You get used to having low overspray really quick.
Robert
Bill Grumbine (Kutztown PA)
>John, I have a Walcom Slim S conversion gun I bought from Jeff Jewitt a few years ago. I don't spray a lot of turnings (although I bought this primarily for a production job of turnings I used to do) but is does a very nice job and uses very little air. It gets used on flatwork mainly, although it is certainly able to handle turnings. It is not cheap, but it is not real expensive either. In fact, I think the prices have come down a little since I bought mine.
Bill
Re: HVLP Conversion Guns *LINK*
>John,
While running a search for the 3-way Apollo gun mentioned by Mark Kauder, I ran across what looks like a good deal on a CA-Tech outfit under $150. Worth a look at the link. I have a 2-qt. CA Tech pot for when I'm doing larger stuff. Very well made.
mm
Small Gun
Thanks for the input
John Scheideman
>I appreciate your help!
John
