Faceplates
Jeff
>What type of faceplates do you use? I need to get some new ones and have always used steel faceplates in the past - but the price on the aluminum ones at craft supply is attractive. Is there any problems with aluminum faceplates?
Faceplates
Jeff
I use the Don Pencil ones from Woodcraft
Steve Antonucci
>I've never had an issue. Many folks say that steel is stiffer and the mass dampens vibration, but I'm only using 2.5" faceplates on must of the things I turn, so I doubt it matters much.
Aluminum is nice, because if you ever mess up threading a faceplate onto the lathe (like with a big heavy blank...), the faceplate takes the abuse and you spindle doesn't.
That's my 2 cents.
Steve
Re: I use the Don Pencil ones from Woodcraft
Norm Smith in Nova Scotia
>I have 6 or 8 of Don`s aluminum face plates and use them almost daily. I don`t have any problems.
Re: Faceplates *LINK*
Russ Fairfield
>I saw these at Art Liestman's last year. They are the best aluminum faceplates I have ever seen, and the price isn't bad either.
http://www.minkcrafts.com/minkcraft_faceplate_pricing.html
Re: Faceplates
Art Liestman
>For what it's worth, I learned about the Mink faceplates from Curt Theobald. The difference between the Mink and Pencil faceplates (which are otherwise very similar) is the fact that the Mink faceplates have a little fillet on the interior corner connecting the "plate" to the "shaft". I'm not an engineer, but I understand that this makes the faceplate stronger. That's specifically why Curt recommended them to me. Makes sense to me. I have three of them and use them often. In fact, I should probably get a few more...
Another place to look is Darrell Fellmate's web
Don Henthorn
>He tells how to make wooden face plates similar to what I have been making for years. Simply make the blank, drill a hole and tap it for your spindle thread. Then You can make a bunch of these at one time and glue blocks to them and always have fresh dedicated face plate for your project that you can leave until you are ready to part off. You can take it off the spindle and put it back on and it will always be right on. At least it is for me.
Re: Faceplates
John Scheideman
>I have a few steel (John Nichols...no longer available) and a few of the Mink aluminums. I haven't had a problem with either of them and they get a lot of use. I do use the steel ones, however, if I turn anything over about 14" diameter. I think the aluminum ones would handle it but I feel safer with the steel when turning very large pieces. For what it's worth, I thought the Minks were very reasonably priced for good quality faceplates and he was very nice to deal with.
John
Re: Faceplates
>I went to a local salvage yard and bought nuts than fit my shaft and round steel plates called blind plates. (Used for capping gas piping) Had a local machinist weld them up for me and true them. Total cost was about $10 each. Five for $50. Also a good Idea to keep a nut to put on the shaft when you are turning with a drive spur. Or better yet, two thin nuts. If the spur gets locked into the shaft, you can "jack" it off.
Re: Faceplates
Jeff
>thanks to all - I appreciate the input
Re: Faceplates
Russ Fairfield
>An old idea that still works.
You can get a machinist to make and adapter for your lathe spindle with a male pipe thread. After that, you can buy threaded floor flanges for about $5 apiece retail or less than $1 at the surplus and scrap yards.
An alternative if you have Nova chucks *LINK*
Gordon Seto
>I like the faceplate rings that fits the Nova chucks.
I prefer it over regular faceplate is that I don't have to remove it immediately because of the low profile and didn't interfere with the live center. That allows me to flip back and forth to refine the shape. I can leave the chuck on the lathe all the time.
Gordon
Faceplate rings
Re: Faceplates
Wilford Bickel
>The Pencil face plates (which I use) have a lot more holes for screws then the Minks show in the picture. I would worry with only 4 screws as the Mink sets up holding a large blank. I breath a lot easier with the number of screws Don puts in his.
Re: Faceplates-holes
David Staeheli
>I agree, I like lots of holes. But nothing says you can't put your own holes in them. I've done that to a few of my bought face plates.
