Fallen trees
Fallen trees
Barb Siddiqui
Fallen trees
Barb Siddiqui
>Has anybody turned blue spruce? 60' of it on my carport; chainsawing today. Working too hard to consider it yesterday, but getting down to 30" trunk diameter soon. Is it just ratty?
Re: Fallen trees
Re: Fallen trees
Russ Fairfield
>If you turn it while it is still alive and the needles are green, and turn it to less than 1/4" thickness, and then soak it with an oil finish, you will discover that Norfolk Island Pine isn't the only wood in the world that becomes translucent when soaked in an oil finish. You will also discover that the Spruce has a similar branch pattern as the NIPine, and doesn't anywhere near being as dark as what I see folks getting with their NIPine.
Re: Fallen trees
Re: Fallen trees *LINK*
Darrell Feltmate
>Barb
I like it for decorative turning. It tends to release turpines (sp?) over a period of time. This will affect the taste of most foods. Spruce is not known as a decorative wood but take a look at an orchestra some time. Most violins, cellos, violas, guitars and the like are spruce topped. Pretty stuff.
Around the Woods
Re: Fallen trees
Re: Fallen trees
Ken Oakley-Sunny St. Cloud, Fla.
>I know Sitka Spruce is a favorite wood for making stringed instruments but this is the first time I have heard of Blue Spruce being used. Learn something new everyday and maybe someday I will be smart.
Re: Fallen trees
Brad Vietje
Re: Fallen trees
Brad Vietje
>Hey Barb,
Check out the recent work by Bill Luce. He posted pics at WoW's of two bowls made from FIR, which has a pretty bad reputation as turning woods go... Now, Bill Luce is, well, Bill Luce -- known all over the turning world for excellent forms and fine work, so maybe I can't make something as nice, but those bowls certainly opened my eyes to the possibilities of the less-than-desirable wood species out there. give it a go !
Safe spinning,
Brad Vietje
Newbury, VT
Re: Fallen trees
Re: Fallen trees
David Staeheli
>I use a lot of White Spruce (Alaskan), and a good soak with walnut oil can sometimes bring out some great chatoyancy. I also seal it with some Danish, just to keep it from picking up dirt and such.
Re: Fallen trees
Darrell Feltmate
>Actually Ken, in Europe Engleman spruce is the preferred variety and in North America it is Sitka spruce, but other top woods are frequently used. Stadivarius used whatever was available in spruce at the time, Engleman when he could get it. Cedar is often used on classical and especially flamenco guitars. Yellow pine has been used to some extent and other species in various countries. Bennedetto has been known to build one of spectacular arch tops in from construction lumber including the spruce top. Reportedly it sounded great and played beautifully. Could it be years of practice for a master builder that made the difference?
Around the Woods
Re: Fallen trees
Barb Siddiqui
Thanks, everyone
Barb Siddiqui
>Lots more work to do (whew that was a Huge tree) but I'll definitely get some of the trunk
saved as it comes up. I did know it as useful for flat work, but didn't know it may have the qualities of Norfolk pine when soaked and turned. I'll definitely get some saved. Thanks!
