Multi-axis ornaments
Gordon Seto
>These are the multi-axis ornaments that I am experimenting with. The body is soft maple, the icicle is hard maple. Comments welcome.
Gordon
Re: Multi-axis ornaments
Gordon Seto
>Here is the second picture.
The dyed ash stand was turned between centers.
Gordon
Doug Thompson near Cleveland
>Gordon,
This is truly outstanding... a very creative design. This has to be tuff to do.
Good Job,
Doug
>Real pretty. I am impressed with the ornaments, but I really like your stand, particularily the cross-bar.
Brad Vietje
Way Cool, Gordon
Brad Vietje
>These are very creative, and even the colored stand suggests some possibilities for future ornaments -- a nice job. Makes the perfectly nice, though more conventional, ornament in the second photo look a little dull by comparison.
On the design side, I think the winged ornament would be even nicer with a little less mass toward the bottom of the spindle, and a shade more at the top. Not so heavy as the single axis ornament shown, but a little wider up top with a transition to a smaller element at the tip.
Safe spinning,
Brad Vietje
Newbury, VT
gil jones
>Very cool!
Allen Neighbors
>Creative and gutsy! :o) Good job.
Ron McKinley
>Beautiful work. I just ordered a DVD on multi-axis turning.....Ron
MountainMan
>I just received a Robert Sorby WoodTurning 2 - CD. It, of course is to demo and sell their tools - but, the fellow doing all of the demonstrations shows how to do multi-axis with the aid of "steb centers" "between centers" with no chuck used... He shows some simple geographic points on the end of either end, or both ends of the wood - verysimple and you don't need to purchase the high$$$$ chuck to accomplish the same thing... order one out for yourself - also ask for CD number 1...they are free!! they didn't send that one to me for some reason...
Regards
The MountainMan
Re: Multi-axis ornaments *LINK*
Gordon Seto
>"verysimple and you don't need to purchase the high$$$$ chuck to accomplish the same thing... "
The MountainMan,
I am afraid you may have over simplified in your statement.
I am fairly new to this multi-axis turning, but it fascinates me. I have no financial interest in any chuck. I just want to share the little bit that I know about this subject for discussion.
Probably you have seen the demo from Clive of Sorby.
Turning between centers is the most secure way of doing MA turning. But it also has limitations. By nature of MA, usually your piece is off balance in the lathe. That requires a lot of pressure from tailstock to hold the blank in the lathe. Therefore it is almost impossible to turn anything delicate in the middle.
It would be almost impossible to turn the MA icicles I showed in the pictures. If you apply enough pressure to cause the stebcenter to drive the spindle from the tail stock end, the thin section in the middle would collapse.
The Sorby eccentric, the original Escoulen and the Deluxe Escoulen chucks all have their limitations.
The Sorby needs to have the tailstock engaged all the time when you want to turn anything that is not parallel to the lathe axis. All the boxes in the Sorby example have openings vertical. Sorby uses a 6-side insert into a 12-side socket; therefore it is much easier to turn a symmetrical multi-side object.
The Escoulen chuck ball has 6 positions for 3 holding screws. Theoretically you can reposition them, but not as easy.
The Escoulen chucks are designed around the ball (tilting the axis). The deluxe model with added off center capacity.
The Sorby was designed around the eccentric boss with an added ball socket.
They all do different things.
The original chuck can only tilt the axis. It mainly chucks long grain. You can also get a faceplate as optional accessory, but the size should not be big.
The deluxe is a heavier chuck. Its major chucking is side grain faceplate method. It also comes with a screw center. It works better with side grain than end grain. You can use it to turn MA platters. Besides tilting the axis, it can also add off-set center turning.
For large scale off-center work, securing an unbalanced blank with any chuck without the tailstock is scary if not dangerous.
I am going to post a MA spoon in another thread. It was done with the Deluxe Escoulen chuck.
Here is a link to the boxes made by Jean Francois Escoulen. His work speaks for itself.
Everybody has their own area of interest in turning. MA is not everybody�s cup of tea. I would suggest trying MA between centers first.
Gordon
Boxes by Escoulen
MountainMan
>Yes! Gordon - you do have lots of good info there!!! I have not done any multi axis work - I just noted what I saw in the Sorby CD... If I were going to try the MA technique - I would invest in a steb center and go from there - instead of buying the expensive chuck designed for off-centrer work./.. !!! I bow to your vast knowledge and experience!!
Regards
The MountainMan
