Surplus vaccuum pumps
Ron in Drums PA
>Someone once posted a link for surplus vacuum pumps.
I had saved it, but can not find it right now
Can someone pass it along to me?
TIA
Re: Surplus vaccuum pumps
Re: Surplus vaccuum pumps *LINK*
Russ Fairfield
>Is this it
http://www.surpluscenter.com/item.asp?UID=2005112610274439&item=4-1540&catname=air
Thanks Russ, That's what I was looking for
Ron in Drums PA
Ed in Leaside (Toronto, Ontario)
>You don't have a surplus plate burner in your print shop? That's where mine came from. ;)
Ron in Drums PA
>This is for one of our presses and the spare is used as my vacuum chuck!
Sean Troy
>That one ok for using as a woodturner? Any down side to that model? Thanks, sean
>Sean,
You'll need 220 and it must be placed so that it's airflow around and through the motor is unrestricted; i.e. no soundproof enclosures here. With a thermally protected motor, it will cut off on you if it gets too warm; good for the pump, bad for the bowl. |;-}}}
Know several turners who have bought these, and they like them just fine.
mm
Sean Troy
>Thanks, good to know. The one I have now is 220 and it may be getting near the end of it's life span.It was a rebuild and has served me well for several years and the majority of it in my garage in Arizona. The heat could be 120 in there most of the summer. It did take a beating.
Mike Cunningham (Cape May)
>Hi Sean,
I've had the same pump from the same source for nearly 2 years and it's worked just fine.
Mike
>"This is for one of our presses ...". I spent a few hours in the woodshop this afternoon, trying to remember a place in a press for a low volume pump of this sort. Came back and reread your response. ...LOL
Have you been using a high volume feeder suction pump on your vacuum chuck? Dang thing would prolly suck a bowl up faster than a Pentz cyclone sucks up small dogs, cats, and children. ;-)
Same here
Dominic Greco in Richboro PA
>I've been using the same 220V 1/4 HP vacuum pump now for about 4 years and haven't had a problem with it.
Dominic
Ron in Drums PA
>Halm Jet. You don't need much vacuum for envelopes.
Also, we're digital for all our presses, plate burners are a thing of the past.
>Ahh, the Jet is a machine I've not had my hands on.
I know about film & plate burners being obsolete. A few years ago I sent a member of a Canadian board over to a local used graphic equipment dealer. He said there were more than a few pumps on the shelves. Probably out of the film house that used to be around the corner.
Re; Me too
Mike Nelson
>I have that same pump, ran the pipe through the wall behind my lathe, just loud enough to know its runnin. Guess I'd know if it weren't runnin soon enough!
Re: Surplus vaccuum pumps - Additional Info *LINK*
Rik
>Additional Information from Gast on this unit:
It could be a 0523-P335-G509DAX if so then that unit was made special for a OEM called Storage Tech.
This unit is a oilless rotary vane unit used for a pressure application in the Medical Field. The unit was designed to produce 10psi max. pressure and has a open flow of 4.5cf.
The motor is a 1/4hp, 220 volt-+20%, 50-60HZ, 1 Phase.
The unit can be run at its max 10 psi 24-7-365.
There are still parts made for this unit. It takes a service kit (Gast part # K478A).
all of the equipment on the unit was supplied by the OEM not Gast. We made just the pump.
Although the pump was made for pressure it could be used for vacuum. It would get around 26"Hg max. vacuum with a open flow of 4.5cfm. You will need to place a inline filter on the unit to prevent any foreign material from getting into the unit and causing damage to it. I would suggest the (V400G Gast part #) and a muffler (V425K)this will help quiet the unit. The Gast Rep can give you pricing.
A unit like this today would run around $350. to $400. US.
http://www.gastmfg.com/discus/messages/23/132.html?TuesdayFebruary1220020512pm
